Boat cushions - SailNet Community
 13Likes
post #1 of 28 Old 09-07-2012 Thread Starter
davidpm's Avatar
Boat cushions
I noticed how much room is taken up (wasted) by cushions.
Often they are up to 3 inches thick.
When you have 3 for the cockpit, 2 for the sides, 1 for the quarter birth and two for the fore-peak plus back rests you can easily end up with a 3 foot high stack of cushions on a 30+ foot boat.
It's no trouble if the boat is used for weekends only and kept at a dock.
If however the boat is going to be lived aboard for some weeks and anchored, the sheer volume of cushion material might become a problem when you are trying to make repairs underway.
Has anyone come up with a way to deal with this issue?
davidpm is offline
post #2 of 28 Old 09-07-2012
paulk's Avatar
Re: Boat cushions
Sit on them.
Jgbrown and Mjfossler like this.
paulk is offline
post #3 of 28 Old 09-07-2012
Remember you're a womble
PaulinVictoria's Avatar
Re: Boat cushions
Strap a 3" cushion to your derriere and do away with all the other cushions. Wherever you sit, you have a nice comfy seat
CS Cruiser likes this.
Orange Crush
1974 C&C27 MkII
PaulinVictoria is offline
post #4 of 28 Old 09-08-2012
Re: Boat cushions
Already been done :
For many, this may be the first introduction to the genius of Karl Pilkington.
sww914 and SeaSickFish like this.
MarkSF is offline
post #5 of 28 Old 09-08-2012 Thread Starter
davidpm's Avatar
Re: Boat cushions
Thanks for the comments but I was thinking more in the line of the minimum thickness that would be comfortable for the cushions.
Maybe a 1.5 inch foam of the right density would be good enough.
davidpm is offline
post #6 of 28 Old 09-08-2012
Irrationally Exuberant
Re: Boat cushions
This is one of the reason I've considered getting very dense foam cushions like C Cushions (or Bottomsiders)--they're 1 1/2" thick. A little more svelte in the cockpit and less room when stowed. Haven't pulled the trigger on this yet though--some other boat part keeps snagging the money
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #7 of 28 Old 09-08-2012
Sabreman's Avatar
Boat cushions
We had cockpit cushions on our last boat and they were more trouble than they were worth. On Victoria, we have no cockpit cushions to get in the way. We have 12" square throwable pfd/cushions that we never use. I don't like cushions in the cockpit.
As for the interior cushions, when stored in their normal locations (e.g., V berth), they are no more than 3" or 4" high. Interior cushions are usually high density, but reducing the thickness much less than 3" will result in bottoming out.
AdamLein likes this.
Sabre 38 "Victoria"
Sabreman is offline
post #8 of 28 Old 09-08-2012
JimMcGee's Avatar
Re: Boat cushions
We did cockpit cushions out of sunbrella and dryfast foam so they can stay in the cockpit all season. It makes a HUGE difference not hauling them in and out of the boat every time we get there.
As for dealing with berth and salon cushions, David has a point, they are always in the way when working on the boat.
But then what is the percentage of time you have the interior pulled apart versus relaxing in it. I'll gladly trade off a little more hassle moving them around for the comfort when we're relaxing aboard.
davidpm and Jgbrown like this.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
post #9 of 28 Old 09-08-2012
Re: Boat cushions
Just put in new interior cushions yesterday. 4"+2" of memory foam(which rolls easier and smaller, leaving me a more manageable cushion if need be).
No real way around some of it, but for the cockpit I'll be going a bit thinner if I put in real foam. For now I find a closed celled foam mat(the blue or yellow kind) and a layer of Dri-deck underneath makes a big difference to sit on. The big advantage of this that it rolls up small, both dri-deck and blue foam rolls can get stuffed in unused space somewhere, and as a bonus, I like using the blue foam to kneel on while I work.
The dri-deck seems to really make it more comfortable, and won't collect water, not really it's intended purpose exactly, but both things were sitting in the cockpit and I happened to sit on them and was surprised at the increase in comfort.
davidpm likes this.
Jgbrown is offline
post #10 of 28 Old 09-08-2012
tdw
Super Fuzzy Moderator
tdw's Avatar
Re: Boat cushions
We spend far to much time in the cockpit to contemplate not having cushions at all but when we remake the current one (3" thick) we'll be going slightly thicker (4") and heavier density foam.
What amazes me is the number of boats , ours included, that do not have any way to hold the cockpit cushions in place. As it is now we put ours away when sailing on the wind or the damn things slide all over the place. Couple of tabs to a bit of velcro or press studs and its sorted.
OK so you don't need full cushions when out for a day sail but they are well worth the trouble on passage, even a short overnighter. They allow me to nap in the cockpit when the Wombet is on watch.
JimMcGee and davidpm like this.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
Smelly Boat Cushions Bump Gear & Maintenance 11 04-08-2010 09:50 AM
Do it yourself boat cushions Morgan3820 Gear & Maintenance 9 12-29-2007 10:13 PM
Boat Cushions and Foam j1budo Gear & Maintenance 15 02-23-2007 02:42 PM
Re: Looking for Boat Cushions for S2 27 1985 NewsReader Mass Bay Sailors 0 06-13-2006 07:15 PM
Looking for Boat Cushions for S2 27 1985 NewsReader Mass Bay Sailors 0 06-13-2006 01:15 AM
