Alcohol stoves in use? - Page 3 - SailNet Community
 6Likes
post #21 of 49 Old 09-09-2012
O'Day 272 - "Pana-Sea-A"
Re: Alcohol stoves in use?
Have a non-pressurized Origo which works great!
Mjfossler is offline
post #22 of 49 Old 09-09-2012
Senior Slacker
SlowButSteady's Avatar
Originally Posted by VK540 View Post
Just curious, are there any brand new production boats that use anything else but propane or natural gas? A sign of the times? I was at the Annapolis boat show a couple of years ago but I don't remember if any of the new boats were using anything but propane?
I think at least some J-boats come with Origo stoves as standard equipment. And I've seen them in a number of new trailer-sailor sized boats.
Edit
My boat presently uses pressure alcohol and I was thinking of converting to propane. It seems that is what is used all the other boats I get to board around here.
Didn't your mama ever ask you about your friends jumping off a cliff?
Seriously, try a non-pressurized alcohol stove. They really are much safer, and cheaper to install over-all (the stove-top is more pricy, but that is ALL you have to buy; no tank(s), no regulator, no hoses/tubing, no sniffer/alarm).
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #23 of 49 Old 09-09-2012
Send a message via Yahoo to dacap06
I still use my pressurized alcohol stove. The danger comes at light-off; it is too easy to put too much alcohol in the warming pan. If you do you get a huge flame that could catch the curtains on fire. Once these alcohol stoves are going, they are as safe as anything else that makes open flames in your boat. I asked an old salt to show me how when I first bought the boat and that worked out well.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #24 of 49 Old 09-09-2012
This is one issue that always baffles me. People rush to put propane on their boat to cook with but are terrified of Atomic 4 gas engines! Propane goes BOOM on some poor souls boat every year but there is not one case of an A4 blowing up.
Isn't boating supposed to gives us a break from daily life? Do I need the same conveniences of home that I'm trying to get a break from?
Stick with and enjoy the alcohol stove. The smell, the different routine is part of the charm.
And you won't go BOOM.
Skywalk er
T27 249
SkywalkerII is offline
post #25 of 49 Old 09-09-2012
VK540's Avatar
Sounds good, not ready to jump off the cliff yet but I don't know anyone who is using them around here. I find the oven in my pressure alcohol doesn't seem to get hot enough for cooking some things properly. How is the oven in the non-pressurized for cooking? I am ok with lighting the one I have without burning the curtains (yet) but I pretty much have to light it for anyone one else on board. Got a get a better trained crew!
"BLISS II"
1977 38 foot C&C Mark 1
Hull #92
Sailing the Exuma Islands, Bahamas
VK540 is offline
post #26 of 49 Old 09-09-2012
we like our Origo... simple, works great... we keep the alcohol in the cockpit fuel locker and just use an oz or two at a time to cook a meal... if you add more fuel, it just evaporates
skygazer likes this.
polaris2.11 is offline
post #27 of 49 Old 09-09-2012
Senior Slacker
Do you have the little neoprene gaskets? I've found that they work quite well (if I remember to use them every time).
post #28 of 49 Old 09-09-2012
Senior Slacker
... I find the oven in my pressure alcohol doesn't seem to get hot enough for cooking some things properly. How is the oven in the non-pressurized for cooking?...
I've only used the stove-tops. But I would be more than a little surprised if the oven didn't work just fine.
On the other hand, if I were to install an oven on a boat I think I would take a serious look at one of the smaller Dickinsen diesel ovens, or (if I really felt rich at that moment) a Taylors.
post #29 of 49 Old 09-09-2012
VK540's Avatar
I was just checking out the Orion on the net and comparing it to a propane stove and oven. The BTU rating of the oven on the alcohol system is 5000 BTU and the propane oven was 10,000 BTU. Quite a difference in the rating but I am not sure if any cooking would require more than the 5000 BTU?
"BLISS II"
Hull #92
VK540 is offline
post #30 of 49 Old 09-09-2012
Senior Slacker
Are they the same size? Divide the power rating (BTWs) by the volume of each oven (or perhaps its surface area) for a better comparison.
Shipmate alcohol stoves.... RobHoman General Discussion (sailing related) 19 04-21-2015 02:08 PM
stoves: propane vs alcohol slocum2 Gear & Maintenance 17 08-17-2007 05:17 PM
update alcohol stoves realitycaptain Gear & Maintenance 9 10-13-2003 06:40 PM
Alcohol Stoves Mark Matthews Gear and Maintenance Articles 0 10-26-2001 09:00 PM
Alcohol Stoves Mark Matthews Cruising Articles 0 10-26-2001 09:00 PM
