Internal vs external ballast - SailNet Community
post #1 of 3 Old 09-10-2012 Thread Starter
I was reading about the loss of "Cynthia Woods", the Texas A&M boat whose keel fell off resulting in the loss of one of her crew. The latest report says she had several groundings and had never been inspected but that some sort of bad repairs had been made.
Having an external keel fail is another of my pet fears which is why I love my 8.5M S2 with internal ballast. Of course, internal ballast would seem to limit the length of a keel.
So, why not external ballast where there is an extension of the hull on each side of the keel? Not only would you have vertical keel bolts but also have bolts going horizontal as well keeping the keel from pulling off of the bolts or even allowing the keel to "work" sideways.
Would ultrasonic testing of the keel/hull joint be useful as a way to test the integrity of this area?
Frogwatch is offline
post #2 of 3 Old 09-10-2012
tommays's Avatar
Re: Internal vs external ballast
It is a maintenance item that is out of DIY reach in most cases due to the machinery needed to lift the hull off the keel and out of sight out of mind on most peoples budgets because the failure rate is low
Up here most boats get hauled every year and they seem to give ample warning something is wrong long before they fail
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #3 of 3 Old 09-10-2012
Send a message via AIM to dmchose Send a message via Skype™ to dmchose
Internal ballast does not limit length. Most full keel designs have internal pb ballast. Bolt on keels save on initial costs and in some cases material.
dmchose is offline
Spinnaker Halyards: Internal vs external mast routing mentalfee Gear & Maintenance 5 06-21-2014 05:47 PM
GPS Antenna - Internal or External Tafa Electronics 6 02-26-2012 11:30 AM
Internal or external boom lines led aft karluk Gear & Maintenance 5 06-01-2011 05:13 AM
External Corrosion bob1956 Atomic 4 4 04-20-2007 11:59 PM
Internal Ballast vs. External Ballast windship General Discussion (sailing related) 3 09-15-2002 04:33 PM
