Isaac Damage to rub rail - SailNet Community
post #1 of 8 Old 09-10-2012 Thread Starter
lajimo's Avatar
Somehow during the 8' surge accompanying issac my port side rub rail got hung up on a dock piling and parted about 1/3 of the way forward from the stern. Except for about 7-12" bent outward on each side of the break the rest is still firmly attached. This is for a 1985 hunter 40' - the rub rail is attached at the hull deck joint adjacent and at right angles to the toerail. The dual assembly is bolted every 6" or so down the entire length. The rub rail is one piece.
To fix it I'm thinking remove the whole thing, get it welded back together and straightened out then reinstall. Does anyone have any experience with this - any better/easier ideas? Thanks
lajimo is offline
post #2 of 8 Old 09-10-2012
Cruiser2B's Avatar
Re: Isaac Damage to rub rail
Any Pics? Pics might help qualified people steer you in the right direction
My two lovely ladies!!
USCG 100T Near Coast Master with 100T Inland Sail Endorsement
Cruiser2B is offline
post #3 of 8 Old 09-10-2012
Geoff54's Avatar
Metal stretches when it bends and you can never truly "straighten" it. A good fabricator might be able to make a satisfactory repair but I suspect he’ll have to cut a piece out as it will tend to be longer once “straightened”. I don’t know Hunter’s well – what’s it make of – stainless?? If so it will also work harden making it more difficult. Do you want it to be “perfect” or just functional? If you can get a matching rub rail, it would certainly be easier to replace it. Pictures would definitely help.
Geoff54 is offline
post #4 of 8 Old 09-10-2012 Thread Starter
lajimo's Avatar
I've added a couple of pics to my photo album in my SN profile but am having a hard time getting them to post in this thread.
lajimo is offline
post #5 of 8 Old 09-10-2012 Thread Starter
lajimo's Avatar
Also, the rub rail is steel, very hard and definitely stretched a bit as it bent - see pics in album. Maybe I'll just cut the bent pieces off and fit a replacement in the gap and call it good.
lajimo is offline
post #6 of 8 Old 09-11-2012
Geoff54's Avatar
Ouch!
That looks like an anodized aluminum extrusion. Assuming it is, If you try to repair and weld it you would have to grind off the anodizing and it would be susceptible to corrosion. If you can match the extrusion, you can cut out the damaged section and just replace that piece - maybe make up a couple of neat little "brackets" to cover the join. For the best results I would see if you can replace the whole rail.
Before you posted the pictures I went looking to see if I could get an idea of what it looked like and I bumper into hunter.sailboatowners.com - if no one here has a better idea, you might ask there for a source for the extrusion. I doubt it is exclusive to Hunter - if you are having a problem, you might also try an industrial metal supplier - I don't know who to recommend in your neck of the woods.
I know some Hunters had issues with the hull/deck joint - make sure there is no damage to the joint and everything is sealed up or you could end up with a leak.
Sorry I can't be more help. Good luck.
Geoff54 is offline
post #7 of 8 Old 09-11-2012
Senior Moment Member
SloopJonB's Avatar
That's almost certainly anodized aluminium - trying to repair it is nearly futile. It would require expert welding & metal finishing and then re-anodizing.
Have you contacted Hunter - they might even have some of it on hand.
Otherwise, I'd find something suitable at a big metal supplier and replace the whole thing.
SloopJonB is offline
post #8 of 8 Old 09-11-2012 Thread Starter
lajimo's Avatar
Thanks for all the input, I appreciate the info.
lajimo is offline
Pearson 36-2 rub rail damage Paysay Gear & Maintenance 6 11-19-2012 06:35 PM
Isaac wedges sailboat mast over Popp's Ferry Bridge in Biloxi - SunHerald.com NewsReader News Feeds 0 08-29-2012 04:10 PM
Isaac DivingOtter General Discussion (sailing related) 5 08-22-2012 01:54 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
Water Damage BlueWaterMD Boat Review and Purchase Forum 13 10-09-2008 01:36 PM
