Sailboat trailer value? - SailNet Community
post #1 of 9 Old 09-11-2012 Thread Starter
Windkiller's Avatar
What would be the approx. value of a deep keel heavy duty double axle sailboat trailer with a max. 30,000 lbs capacity? (that's what it says on the tongue)
Probably for boats up to 30-40'
I might have one I can't use and would like to an idea of it's value.
Older but solid probably needs wiring for lights
Windkiller is offline
post #2 of 9 Old 09-11-2012
Re: Sailboat trailer value?
Probably more than a trailer and boat would cost used.
Sell it for what market will bare in your area.
ParadiseParrot is offline
post #3 of 9 Old 09-11-2012
WindKiller,
I may be in the market for a sailboat trailer and would like more info.
How long/wide is it?
What type hitch does it have - gooseneck, ball hitch etc.?
Are the bunks adjustable?
Who built it?
What condition is it in? Wheels, tires, axles, brakes, is the frame sound?
What state is it in?
SJ34 is offline
post #4 of 9 Old 09-11-2012
4KSB driver.
SHNOOL's Avatar
Dock
A #30,000 trailer? REALLY? It's a 5th wheel semi trailer right?
1983 WD Schock Wavelength 24. Production boat limit tester, blue-water bucket owner, with wine taste on a beer budget.
SHNOOL is offline
post #5 of 9 Old 09-11-2012
Must be a semi with a commercial license. The max gross combined vehicle weight is 26001 before it is commercial.
What do you plan on pulling it with? What kind of hitch?
Sent from my DROID X2 using Tapatalk 2
Mark
1975 Hunter30
mjf55 is offline
post #6 of 9 Old 09-11-2012
To help you get sort of in the ballpark price wise, a new trailer for a 30-40' boat rated at ~15k lbs would go for $8,000-$15,000 depending on options like galvanizing, self launching, etc. I have been watching for a trailer for my boat and most of the used trailers I see go for between half of the new value if in good shape and 3/4 if in truly excellent shape. The few trailers that I have seen which are in fair shape go for significantly less.
If the trailer really is rated for 30k lbs, it is likely commercial and requires more than a 1 ton pickup to haul so I have no idea what the pricing would be then.
On that note, if anyone has one for sale in New England that has a capacity of 11k lbs or greater, let me know.
klem is offline
post #7 of 9 Old 09-11-2012
Boatswain
IronSpinnaker's Avatar
Canada's law is 4500 kg and over for Commercial. 26001lbs is the US law.
Take the trailer to a certified scale and weigh it... Then multiply by the current scrap value and you have a starting point. Nothing is worth more than you can get somebody else to pay you for it. Scrap value lately is often more than market value on many things.
A 30K rating on the tongue does not indicate the rating of the trailer. Sounds like a pintle and ring hitch, they are usually 15 ton.
In the US we calculate weight ratings at the weakest link; the tires. Multiply the weight rating of the tires by the number you have and you have the Max rating of the trailer.
Signature
IronSpinnaker is offline
post #8 of 9 Old 09-11-2012
I have observed that location has a lot to do with boat trailer values. Longitude, to be more specific.
Up North, where the water gets crunchy, most people have to either have a trailer or pay a yard to pull andlaunch their boats. They are harder to find, easier to sell and more expensive there.
Down South, where some boats are never taken out of the water, a lot of owners don't have a trailer. Trailers are less valuable, due to the lower demand and less expensive down there.
Sounds like yours will sell itself, though. Good luck.
Yankee is offline
post #9 of 9 Old 09-12-2012
mitiempo's Avatar
I think you mean latitude.
Brian
mitiempo is offline
Sailboat Trailer capncook General Discussion (sailing related) 5 07-02-2010 09:28 AM
sailboat trailer needed anson General Discussion (sailing related) 0 11-15-2007 11:26 PM
In need of a trailer for a 23'' sailboat natejount Boat Review and Purchase Forum 0 10-10-2003 04:37 AM
In need of a trailer for a 23'' sailboat natejount Boat Review and Purchase Forum 0 10-10-2003 04:36 AM
Seeking sailboat trailer RogerLS General Discussion (sailing related) 0 10-29-2002 12:43 PM
