To flatten or not to flatten - SailNet Community
post #1 of 6 Old 09-13-2012 Thread Starter
mbowser's Avatar
I am approaching the point in my Alberg 35 recore/restoration where I have to decide whether to add a flattening agent to the final coat on the decks. I've done 2 coats of Interlux Perfection on all the areas that will be exposed (cabin top sides and the deck perimeter/bulwark). I will be using KiwiGrip for the non-skid areas which is already non-glossy.
I had planned on adding flattening agent to give a semi-gloss or satin finish to the cabin top and deck perimeter surfaces to cut down on glare, but after 2 coats, I am really liking the glossy finish. Now I'm rethinking my original decision to add the flattening agent to the final coat and I'm wondering if the glare from the exposed surfaces will be a real problem or is it sufficient to make sure the non-skid areas (KiwiGrip) are not glossy?
Photos here: Magic #16: Woohoo! Paint Time
Any thoughts appreciated.
mbowser is offline
post #2 of 6 Old 09-13-2012
Re: To flatten or not to flatten
If you've got KiwiGrip on the majority of the deck area and cabin top I'd not worry about glare from the remaining gloss... even if you're using a bright white for the non-non-skid areas. You already like the glossy look, it will be easier to keep clean as well.
On a previous boat we did the entire deck in white, including nonskid areas, and never really had an issue with glare.. generally if it's that bright out you're already wearing sunglasses anyhow.... and the white was much cooler underfoot than the original grey.
Faster is offline
post #3 of 6 Old 09-13-2012
Barquito
Barquito's Avatar
That paint looks good. I think most of the areas that would have caused glare problems are the horizontal surfaces and they have non-skid anyway. I would keep the beautiful shine.
Valiant 32
Barquito is offline
post #4 of 6 Old 09-13-2012 Thread Starter
mbowser's Avatar
Thanks for the responses, I think I am going to forgo the flattener for the third coat and stay with the high gloss. After looking at a complete disaster for several years, the shiny cabin top will be the icing on the cake!
mbowser is offline
post #5 of 6 Old 09-14-2012
Good decision!
I did add flattening agent on my previous boat paint and I can tell that the gloss is much easier to keep clean and it last longer - the flattened paint becomes kind of chalky after a few years.
The small amount of surface left exposed will not have any impact on glare and will look great.
I just completed my Kiwi Grip application and it was easy. I spent a lot of time masking, ensuring rounded corners, etc. I used a serrated spreader (1/8) for the KW and the small roller, I am really satisfied.
BTW, great paint job and good luck with the project.
SVTatia is offline
post #6 of 6 Old 09-16-2012 Thread Starter
mbowser's Avatar
I'm happy with my decision, got the third and final coat on today and it looks great (as long as you don't inspect too closely ). I'm looking forward to the KiwiGrip project, I've heard good things about it, but it's new territory for me so lots of on the job learning in the coming weeks. I'm sketching out the taping pattern tonight. I'm pretty sure that will be the bulk of the time spent on the project. I'll be getting a notched spreader like you recommended tomorrow.
mbowser is offline
