lubing mast track - SailNet Community
 2Likes
post #1 of 12 Old 09-13-2012 Thread Starter
Barquito
Barquito's Avatar
lubing mast track
I forgot to lube the mast track when stick was on saw horses this past winter. I don't really want to climb the mast to spray it. Would it work to just stick some parafin wax on a few of the slugs and raise and lower the sail a few times?
Valiant 32
Barquito is offline
post #2 of 12 Old 09-13-2012
Seņor Member
PorFin's Avatar
Re: lubing mast track
Might work, but probably not optimum. Parafin's a poor choice for lube; you'd be much better off going with something like BoeShield T9 or McLube's SailKote.
Take a gander at this thread for a "no climbing required" solution.
CapnBones likes this.
PorFin is offline
post #3 of 12 Old 09-13-2012
CapnBones's Avatar
Sweet, I was going to look that same thread up. I am still amazed at that invention on there.
CapnBones is offline
post #4 of 12 Old 09-13-2012
Superior Sailor
Squidd's Avatar
Just squirt the first 6' or as high as you can reach on the mast track,, hitting the slugs with silicon spray and they'll carry it up the mast for you...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #5 of 12 Old 09-13-2012
Learning the HARD way...
eherlihy's Avatar
For your reading pleasure;
I had some old track slides. I took 2 of them, and connected them with a 1" bar of aluminum. I then fit a piece of the really coarse (red) scotch-brite pad between them. Then, I taped an old hinge to the top of a can of McLube Sailcoat, so that when I pushed the hinge, it activates the sprayer. Finally, I taped the can of McLube to the 1" aluminum bar.
I attach a halyard to the top track slide, and a line to the bottom and feed the whole contraption into the track. I also have another line attached to the hinge, so that I can use the spray can remotely.
I pull the thing up and down the track a few times, so that the scotch brite can do it's thing, then, starting at the top, I pull the whole mess down the track while activating the sprayer.
Works like a champ!
Here are two pics;
From the side, you can see the inventive use of Duct tape.
I connect a halyard and downhaul onto that loop of string, and a piece of fishing line onto the hinge.
From the top;
My two posts edited into one.
MarkSF likes this.
eherlihy is offline
post #6 of 12 Old 09-13-2012
eherlihy's Avatar
I'll take that as a compliment
Thank you, but as I mentioned in the other thread, I was inspired by something that I read somewhere (but for the life of me I can't remember where - In the words of our former VP, "what a waste it is to lose one's mind")
Feel free to grant me rep. points though.
eherlihy is offline
post #7 of 12 Old 09-13-2012 Thread Starter
Barquito
Barquito's Avatar
PorFin - I remember that posting. However, I'm too lazy to put that together. I thought I read somewhere that parafin wax is used? Maybe that is a bit old-school (just a few months more advanced than whale blubber).
Valiant 32
Barquito is offline
post #8 of 12 Old 09-13-2012
Seņor Member
PorFin's Avatar
The main drawback of parafin is that it will catch and hold airborne dust/salt/grit, which is what we're trying to fix in the first place...
The best option is something that will leave a very thin, dry film in place; parafin will leave a relatively thick coating which when warmed becomes a semi-liquid and thus a great place for all those grit particles to find a home.
You could try and cobble something less challenging together, but still using the halyard with a downhaul as your climbing monkey.
PorFin is offline
post #9 of 12 Old 09-14-2012 Thread Starter
Barquito
Barquito's Avatar
OK, I'm convinced. Looks like modern lube it is.
Valiant 32
Barquito is offline
post #10 of 12 Old 09-14-2012
ebs001's Avatar
I've put one of these gizmos on my t'do list when I go back to the boat for the winter.
ebs001 is offline
Lubricating mast track BrianConley Gear & Maintenance 8 05-29-2013 10:44 PM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
mast track filler?!?!?! blt2ski Gear & Maintenance 16 04-18-2010 02:13 PM
Radar on the Mast Track?? Bene505 Gear & Maintenance 9 12-19-2008 12:57 PM
Mast Track Issues Sue & Larry Gear and Maintenance Articles 0 06-03-2002 08:00 PM
