HELP - SailNet Community
post #1 of 4 Old 03-01-2004 Thread Starter
HELP
I need some help and info on my Tillerpilot TP500 Navico that is not working properly, When I set the course by pressing the auto button, it start changing step by step the course making a 360 degree turn, if I press the man button it maintain the course but it doesn’t make any correction, it just keep the tiller in the 0 position, Any suggestions on the problem?
Thanks in advance
Jorge -Genesis
jzlatar is offline
post #2 of 4 Old 03-05-2004
HELP
have you checked to voltage at the autopilot? possibly you don''t have the right guage wire going from the battery to the autopilot and are losing too much voltage...
gaurre3 is offline
post #3 of 4 Old 03-07-2004
HELP
My simrad (Navico) TP30 works pretty inconsistantly and I wish I could figure it out. I feel your pain.
Irwin32 is offline
post #4 of 4 Old 03-22-2004 Thread Starter
HELP
Problem solved...The autopilot was installed on te port side, it came with a factory set for mounting on the starboard side and the previus awner have never used it and he did not have the owners manual.It was changed to the wright side and now it is working perfectly. To change the mounting configuration of the tillerpillot I only have to hold down the set/auto key and connect the tillerpillot to 12 volts then have to press the port key if I want the port hand munting.
Thanks to other tips
jzlatar is offline
