3 strand nylon lifelines? - SailNet Community
 1Likes
post #1 of 21 Old 09-15-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
I've had a bunch (470 ft) of 1/2 inch nylon 3 strand kicking around in the shed for years and I've been trying to figure out what to do with it.
I was recently contemplating replacing my lifelines and it struck me, why not use 3 strand nylon for my lifelines? That would get rid of a big chunk of the line. I know some people use spectra/dyneema these days and I HAVE seen 3 strand nylon lifelines before but when I did a search here and on google I got very little info back on using 3 strand nylon to make lifelines.
Pros and cons anyone? From my perspective I have the following list of pros/cons:
PROS:
--Stretches when loaded thus adds some dynamic factor to the fall and might be less likely to fail.
--Can be cut in an emergency
--Easy on the hands
--Easier to catch/grip if actually trying to fall/slide overboard
--Repairable with parts at hand
--I got the stuff laying around
--I might finally remember once and for all how to splice when I'm done
Cons (vs uncoated stainless)
--Might be weaker?? Stretch might be bad if I have my physics wrong.
--Chafe on stanchions
--Chafe on poorly led sheets
What does the hive mind think?
MedSailor
MedSailor is offline
post #2 of 21 Old 09-15-2012
Zanshin's Avatar
Re: 3 strand nylon lifelines?
You forgot UV deterioration and I would say that the stretch is a negative. I replaced my lifelines on the previous boat with Dyneema lines (and Brummel Splices) and was happy with that.
There is a reason that the ORC rules stipulate only steel or Dyneema for lifelines and no other material is acceptable.
Zanshin is offline
post #3 of 21 Old 09-15-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
How is the stretch a negative? It seems to me that anything that would reduce the multiplied loads at the ends would be a positive, but then again I'm thinking like a climber here....
Do you have a link to any commentary on why they ORC rules stipulate low stretch? I wonder if they just only had one type of line (stainless) and then, once petitioned, allowed Dyneema. I don't think too many racers would have tried 3 strand. It probably seems heavy to them...
MedSailor
post #4 of 21 Old 09-15-2012
JMHO, but I think 1/2" line would look funny (too big), then get dirty and look worse.
Jeanneau 54DS
Minnewaska is offline
post #5 of 21 Old 09-15-2012
Crealock 37
sailak's Avatar
Dock
The stretch would be good at reducing loads but I think stretch will also allow you to "fall through" the lifelines if they give way enough. Nylon stretches a lot, I doubt you could get the lifelines tight enough to be useful.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #6 of 21 Old 09-15-2012
Senior Slacker
SlowButSteady's Avatar
Remember, if a line stretches it also springs back. Falling against a stretchy line might well produce a very difficult to control "rebound", which in turn could both lead to injury and still cause one to go over the side. Probably best to have as stiff a material as possible for lifelines.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #7 of 21 Old 09-15-2012
pdqaltair's Avatar
Stretch is just a word until you see (or calculate) it in action. I think it would help the OP to tie a length between 2 trees, 2 feet off the ground. Then put your foot on it and take it nearly to the ground.
True, it would be impossible to break a nylon lifeline because of the energy absorption and true it would put less strain on the rest of the system, but It would lack any security when used for balance and it would likely be easier to fall through.
Oversize polyester braid would likely work, but not nylon.
Coincidentally, I have a large pile of retired climbing ropes (8.5-11 mm nylon) and have also found only limited applications.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #8 of 21 Old 09-15-2012
Zanshin's Avatar
How is the stretch a negative?...
MedSailor
I believe too much stretch is a bad thing. Even with steel lines that have no stretch (at typical stresses from a 250Lb body falling overboard and being stopped) the lifelines already have quite a bit of "give" from the stanchions flexing and the endpoints of the line giving a bit as well.
The ORC rule can be found here: ISAF Special Regulations
But I see a new addendum:
e) RORC prescription to ISAF OSR: 3.14.6 e) has been deleted, removing the reference to HMPE (DyneemaŽ/SpectraŽ)
f) A taut lanyard of synthetic rope may be used to secure lifelines provided the gap it closes does not exceed 100 mm (4 in). This lanyard shall be replaced annually at a minimum.
g) All wire, fittings, anchorage points, fixtures and lanyards shall comprise a lifeline enclosure system which has at all points at least the breaking strength of the required lifeline wire.
TABLE 8
under 8.5 m (28ft) 3 mm (1/8 in)
8.5m - 13 m 4 mm (5/32 in)
over 13 m (43 ft) 5 mm (3/16 in)
So I stand corrected and not even Dyneema is sufficient for offshore racing; just any synthetic for the endpoints.
Zanshin is offline
post #9 of 21 Old 09-15-2012
Nylon also stretches when wet. Significantly.
So if you plan to use it for lifelines, you want to pre-wet the cord before you string it, and then get it good and snug while it is still wet.
Otherwise, they'll sag during normal use as they pick up splash, spray, or rain.
hellosailor is offline
post #10 of 21 Old 09-15-2012
The only way I could see an application for 1/2" nylon three-strand as a lifeline is if you wanted to rig a temporary chest level line when at sea. Even then, I would rather have something with less stretch.
Use it for docklines, anchor rodes, things for which it was designed. Or else make some salty rope mats.
Splicing won't seem difficult at all after you've tied one of these.
mitiempo likes this.
knothead is offline
3-strand pricing T37SOLARE Gear & Maintenance 5 05-06-2009 08:45 PM
3-Strand Polyester or Nylon trantor12020 Gear & Maintenance 21 01-28-2009 09:30 AM
Can I use uncovered 12 strand for halyards? zz4gta Gear & Maintenance 11 08-14-2008 10:24 AM
Mail's Longhaul in Strand next week (Helderberg) NewsReader News Feeds 0 02-15-2007 04:15 AM
Braiding 8 strand multiplait RoadTool Seamanship & Navigation 3 02-26-2006 01:47 PM
