Seeking interior laminate advice - Page 2 - SailNet Community
 3Likes
post #11 of 24 Old 09-15-2012
Re: Seeking interior laminate advice
Good lord.... that doesn't even qualify as patina... leave it alone!
However, you may want to test emory cloth or a very fine steel wool. You will probably have to stain everything if you want all to match.
Why are people happy to accept science which makes their life easier while rejecting science that makes their faith or beliefs more difficult?
cupper3 is offline
post #12 of 24 Old 09-15-2012
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
I still say that the only way to get a good answer is to have someone look at it in person that could tell you if there is going to be a problem staining it to match. Pictures can make things look far better than they are and sometimes worst.
As the others said that is a very nice looking boat and if this is the only question mark between buying or not buying then pay if you have to and have a cabinetmaker look at it.
I love the white cushions, but with me around they would be white for about a day
Good luck,
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
Sumner10 is offline
post #13 of 24 Old 09-15-2012
What you are talking about is refinishing wood, not repairing laminate. Matching factory applied glossy finishes is hard, it often takes a lot of trial and error. I have done it before, but it takes patience. Getting a quote from a furniture restorer would be a start. The boat looks pretty new, so another option is to contact the maker and ask what they used. This may not be an exact match as color and gloss change with time and not all batches of stain etc are the same, but could be close enough.
Also, lots of "wood" on newer boats is a thin veneer over ply or MDF. You have to be very carefull working with it as it can ben damaged by too much sanding or stripping. The trim pieces should be solid, but the larger flat areas, like the nav station top, could be very thin.
baboon is offline
post #14 of 24 Old 09-15-2012
My new counter tops.
One 4X8 Formica sheet from a big box store.
dick
Last edited by Flybyknight; 09-15-2012 at 07:47 PM. Reason: forgot to put the links in?
Flybyknight is offline
post #15 of 24 Old 09-15-2012
Now that we see your pics, and in light of the original question, I strongly recommend that you follow Kd3pc, and cupper3s advice and don't mess it up. Refinishing trim work like that is best left up to the pros.
For example, do you know that the pros find a brand new Badger Hair brush useless unless it is "broken in"!
That's openers.
BTW, I think that you have found yourself one fine boat.
dick
post #16 of 24 Old 09-15-2012
Plywood I can understand, but MDF? That's scary. That stuff won't stand up in a humid environment for any length of time.
See manufacturers MDF manual here. If any boat manufacturer is using it, they should be outed now!
cupper3 is offline
post #17 of 24 Old 09-16-2012
That is a good point, I looked at a Beneteau recently and some of the cabinets did look like laminate or veneer over something that was not quite plywood, but I do not know if it was MDF. Do they have HDF, VHDF? Pressed compacted used wine casks?
baboon is offline
post #18 of 24 Old 09-16-2012
mitiempo's Avatar
Any Beneteau I have worked on is veneer (thin) over plywood. The finish is hard to match though. The actual countertops are laminate - Formica or similar.
Brian
mitiempo is online now
post #19 of 24 Old 09-16-2012
Senior Moment Member
SloopJonB's Avatar
Cups, Cups, Cups - you know better - STEEL wool has NO place on a boat, ever, under any circumstances.
Unless you want it to look like it has chicken pox that is.
SloopJonB is online now
post #20 of 24 Old 09-16-2012
From what I could see in the pics, the damage looks relatively minor. I would try using a product like “Liquid Gold” or “Old English” that you can find at most grocery or home improvement stores. Teak oil could also be used, but it will stain any laminate it comes in contact with. All are oils that will help clean and recondition the wood. They will cause the scratches to darken and blend in more with the surrounding wood.
Use blue painters tape to mask off any laminate, moisten a rag with the oil, and just wipe the wood down. Easy, cheap, and you may well be satisfied with the results.
Tweegs is offline
Interior refit advice texianbiker General Discussion (sailing related) 6 04-04-2012 04:19 AM
Need advice on new interior cushions/bedding!! DovaRossi Cruising & Liveaboard Forum 3 01-15-2012 11:34 AM
Boat interior re-design, advice needed! RichP Sailboat Design and Construction 14 09-02-2008 05:35 PM
SEEKING ADVICE! seawindgr Boat Review and Purchase Forum 0 08-31-2002 09:57 PM
Seeking Jib Traveler Advice dchew Racing 0 05-05-2002 05:03 AM
