Cleaning a fuel tank - Page 3 - SailNet Community
 6Likes
post #21 of 25 Old 03-27-2013
Re: Cleaning a fuel tank
Round covers (think of the heavy manhole covers in the street) cannot fall into the sewer system. Or in this case, a round inspection port cover cannot fall into the fuel tank. Any other shape CAN fall in and then get lost under the tank contents.
I just had my tank cleaned by the boat yard (using a high pressure polishing system). The OP should ask the yard where gets other work done, or a yard attached to his marina. The polishing system is generally just several LARGE racor type filters in parallel with a pump and hoses to allow them to pump the contents out of your tank, filter them and then pump the fuel back in. If you pump it back in under pressure you can use the high pressure spray to wash down the inside of the tank.
sd1953 is offline
post #22 of 25 Old 03-27-2013
rbyham's Avatar
I just went through this asw ell. Ultimately a new tank from Moeller was within $20 of clean out fee. So I trashed the old and went new thinking the new tank would also be ethanol tolerant. I did have to modify tanks beds but not much. New tank, lines, filters and carb rebuild have my atomic 4 purring with no worries about residual tank gunk.
rbyham is offline
post #23 of 25 Old 03-28-2013
Closet Powerboater
MedSailor's Avatar
Originally Posted by ambianceack View Post
About four years ago I installed an 8-inch inspection port into the top of my 20 gallon aluminum tank. I purchased it at Seabuilt - Access Plate Systems
Nice!
But at $171 each (and I need three) that's a bit rich for my blood! My local stainless shop quoted me $50 each for 3 custom covers, but I cheaped out and went for $10 plastic ones.... Not shiny, but they do keep the diesel in the tank and the dust out of it.
MedSailor
MedSailor is offline
post #24 of 25 Old 03-28-2013
I agree with you about the cost of the access plate but the cost of doing something twice is just as much since time, in my opininon, is more expensive. Moreover, once my tank is back in place I do not have easy access to readily check on the integrity of a home made cover, especially if there is a potential fuel leak.
ambianceack is offline
post #25 of 25 Old 03-28-2013
Fresh water refugee
katsailor's Avatar
Originally Posted by MedSailor View Post
Nice!
MedSailor
With my luck, I would find out the plastic ones are interacting with my diesel fuel at an extremely inappropriate time, $50/ea would be palatable instead of wishing I had not cheaped out when at sea.
MedSailor likes this.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
Cleaning out fuel tank pegasus1457 Diesel 16 10-04-2011 01:31 PM
Cleaning fuel tank Dreamin Gear & Maintenance 4 04-05-2009 07:41 AM
cleaning diesel fuel tank WaltG Gear & Maintenance 14 11-22-2007 11:12 PM
cleaning out gas tank calomar Gear & Maintenance 6 08-17-2002 10:36 AM
Cleaning Fuel Tanks Sue & Larry Gear and Maintenance Articles 0 03-21-2002 08:00 PM
