solar hot water - SailNet Community
 6Likes
post #1 of 20 Old 09-16-2012 Thread Starter
solar hot water
Crew
Has anyone out there in sailing land seen, or built a sloar hot water system for their sailboat? I'm looking around for a design to roof mount on Clarity, but if it's been done successfully I'd appresiate hearing about it. Cheers. Bill
clarity36 is offline
post #2 of 20 Old 09-17-2012
old guy :)
rikhall's Avatar
Re: solar hot water
These work really well, stow well when not in use and are reasonably priced.
Sometimes simple is good.
Rik
dacap06 likes this.
Irwin Citation 34
Mystery
rikhall is offline
post #3 of 20 Old 09-17-2012
Greenflash35's Avatar
Re: solar hot water
How about one of those non marking black hoses.
GreenFlash35
Greenflash35 is offline
post #4 of 20 Old 09-17-2012
Re: solar hot water
I haven't, but I've thought about it. Because I have four separate water tanks, I've thought of insulating one, and using a solar pump and vacuum tubes to make it a hot water tank. Haven't even experimented yet, but I would mock it up first with a five gallon bucket before I altered the plumbing.
WanderingStar is offline
post #5 of 20 Old 09-17-2012
Mobnets's Avatar
Re: solar hot water
My boat has never had a hot water heater installed. I have no interest in a shower in the head, but would like to have it readily available in the galley. My plan is to get a 6 gallon marine hot water heater and run it on electric when on shorepower but not hook it up to the engine cooling system as per usual for use when off the grid. I don't want to run the engine just to heat water. My thought is to circulate (with a low-volume solar-powered pump) warm/hot water through the heater through a modest-sized cabintop collector when not on shorepower. I'm going to experiment with it before next season to see if it's feasible before trying it on the boat.
Mobnets
1973 Chance 32/28 "Westwind"
Mobnets is offline
post #6 of 20 Old 09-18-2012
Closet Powerboater
MedSailor's Avatar
Re: solar hot water
Rik
Really, they are awesome. Even in the PNW where sun is scarce they are good. If you can't get the water quite hot enough, a kettle of warmed or boiling water will get it to the right temp. Also, buy the biggest one they make. Even if you don't need all the capacity the extra surface area will help it get hot faster.
My two "Sun Shower" brand showers (now owned by Stearns) are still going strong after 10 years of abuse and neglect. They also have a temperature indicator on them (think forehead thermometer) which is nice as well.
MedSailor
MedSailor is offline
post #7 of 20 Old 09-18-2012
Closet Powerboater
MedSailor's Avatar
Re: solar hot water
I had a friend who tried that in Eastern Washington (where it is very sunny and hot in the summer) and it ended up not working. Apparently there was a lot of heat loss in all the surface area of the tubing and the tubing of large enough diameter (1/2") that the middle never got very warm.
On the other hand our swimming pool in Australia has a system that used a very small pump and a bunch of very thin rubber tubing (1/8" diameter probably) that had flanges on it to make the black rubber surface area larger. It added quite a few degrees (maybe 10?) to our outdoor pool.
It was something like this:
Hot Sun Flexible Solar Swimming Pool Heating Collector Panels
It seems that the solar pool heating industry has quite a few offerings that would fit the bill. There are even good instruction manuals and diagrams that show how to make the system.
Just substitute your "tank" for their "pool" and you should be good to go. This one in particular (linked above) looks good because the rubber is flexible and can be run anywhere that is convenient on the boat.
Nice idea BTW. Let us know how it turns out!
MedSailor
WanderingStar likes this.
post #8 of 20 Old 09-18-2012
aeventyr60's Avatar
Re: solar hot water
Sunshower more then enough for our needs. When we were in mexico we had to put a T-shirt around the thing as the water was way TOO hot for showering.....
"Your dreams minus your doubts equals your net worth"
Life is a short journey, filled with emptiness and pain. Get all the sailing and booty you can.
aeventyr60 is online now
post #9 of 20 Old 09-18-2012
Send a message via Yahoo to dacap06
Re: solar hot water
Rik
Yes, Rik has it right. I have one of those and it works pretty well. You get enough to do a Navy shower with warmish water after you put it in the sun for two or three hours. That's great for warm weather but I want something hotter when it is cool. That's the time to pull up to a dock, plug in the electric, and use the hot water heater and electric heater.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #10 of 20 Old 09-18-2012
Tim R.'s Avatar
Re: solar hot water
Mobnets
Will you not need to run your engine to charge batteries? Wouldn't it be a good idea to plumb the engine cooling to the WH so you can get hot water if needed or as a by product of running the engine for some other purpose?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
water maker solar panels warrenbear Introduce Yourself 4 04-27-2012 02:40 PM
salt, water, solar = hydrogen! deniseO30 Gear & Maintenance 44 03-21-2012 12:01 AM
Any ideas for solar hot water to main h/w tank? PopeyeGordon Gear & Maintenance 18 03-04-2011 06:00 PM
solar to hot water heater? SanDiegoChip Gear & Maintenance 18 02-11-2010 04:56 PM
Provisioning water and power. Solar Recharging is it the right answer? bkohatl Provisioning 20 09-28-2007 01:23 PM
