Yanmar 2GM raw-water pump? HELP - SailNet Community
post #1 of 4 Old 09-17-2012 Thread Starter
First String
I have a 2gm 13hp Yanmar engine in the C&C 30 MK1. The water pump shaft seal sprung a leak. There was a spare on the boat when I purchased it. The problem is the fittings comming and going and differnt sized and the impeller seams to be 1/2" or sow larger than the one I took off. It has the same pully and mount as mine. Not sure if its o,k to use? I am trying th have the one I took off rebuilt. Any help out there of if the 2gm had 2 differant choices for a raw-water pump.
ltgoshen is offline
post #2 of 4 Old 09-18-2012
wduncan50's Avatar
Re: Yanmar 2GM raw-water pump? HELP
I had the same problem with my raw water pump on my 2gm 13 when I bought my 1981 30' Hunter last year. I called my local Yanmar distributor and they told me they had a complete replacement pump with bracket much cheaper than the rebuild parts. I bought this replacment and found it fit but the intake and output fittings were in slitghly different places and the output was a bit different sized. I had to buy a new output hose but everything else worked.
I'm not at the boat so I don't have the part number but you can call these people and get it. Yanmar Distributor Marine Pro of Central Florida - Complete Re-power Service
Will Duncan
wduncan50 is offline
post #3 of 4 Old 09-20-2012 Thread Starter
First String
Thanks, I have a guy. He is going to change the fittings out on the used pump or my spare and he will rebuild my old one.
ltgoshen is offline
post #4 of 4 Old 09-24-2012 Thread Starter
First String
Just an up-date to the story. The pump I had as a back up pump is just a little larger than the pump I took off the engine. There is no way to make it work. The suctiion side is too close to the engine mount. I will have to rebuild my original pump and sell this good back up. The back -up must be for a 2GM 20 or somthing?? Anybody needd a good pump? I will trade if for a good pump.
ltgoshen is offline
yanmar sea water pump mystery silentfaith Diesel 0 10-17-2011 10:24 PM
C&C 32 raw water pump for 2gm yanmar bigchump C & C 6 04-15-2011 08:55 AM
Yanmar 2GM20F, raw water pump HappySailors Diesel 4 11-20-2010 12:56 PM
Yanmar Water Pump dashman Diesel 1 08-16-2009 02:02 PM
Water Pump Yanmar 2GM20F puff6022 Gear & Maintenance 13 02-27-2008 09:16 AM
