Old 09-19-2012
Lost at Si!
lostatsi is on a distinguished road
2 part dingy paint
I have an old Achillies RIB. I am considering using the 2 part paint offered by a couple of different manufacturers. Oddly enough their web sites state that it will make the old dingy like new yet I'm having difficulty finding reviews by users other than the on site glowing reviews.
At a cost of over $200 it is both a considerable savings over a new hypolon boat and yet a lot of money to waste if it doesn't work.
I don't expect it to renew the 20 year old boat forever. I'm thinking that getting at least 1 year might be worth it. My use will be in very sunny conditions, no plans to keep covered. Boat has fabric showing on several top spots.
If you have used this product I would love to hear your thoughts.
  #2
Old 09-19-2012
MarkSF is on a distinguished road
Re: 2 part dingy paint
I did it last year - complete waste of money. The problem is that the final finish is a matt grey paint that shows up every single mark and scuff. Any kind of scrape against something takes both layers off, leaving red. The stuff is not hard wearing at all. The best thing I can say is that the base layer filled a couple of pinhole leaks and repaired a couple of spots where I was down to the fabric.
I'd suggest repairing any worn spots only, and buying a cover, unless you feel the need to spend $150 turning an old ugly dinghy into..... an old uglier dinghy.
Bristol 31.1
  #3
Old 09-21-2012
mbowser is on a distinguished road
I just finished up painting the decks of my boat with Interlux Perfection and I'm pleased with the results. The gloss is incredible and the finish is really hard. From what I've read on the product, you can expect it to hold up for several years at least. I went with Perfection because it is touted as a 'do-it-yourself' finish and is intended for the roll and tip method (as opposed to spray). I believe several other paint manufacturers offer similar products but I have no experience with them. I also did my sailing dinghy with the same product and it has held up well dragging it over sand since I did it last month.
Based on my experience, I'd say 90% of time spent on the project was on surface prep and priming; the final painting part was easy, but these 2 part paints hide no sins. If you have any imperfection on the underlying surface, the glossy paint will not cover it and will actually highlight it and make it look worse (it will be shiny though).
I recently wrote up my thoughts on Perfection here
  #4
Old 09-21-2012
Your experience with Perfection has no relevance to painting a Hypalon inflatable dinghy.
Bristol 31.1
  #5
Old 09-21-2012
My bad, I didn't see that it was an inflatable.
You may post attachments
You may edit your posts
1 part poly paint success? SailingWebGuy Gear & Maintenance 6 01-10-2011 06:15 PM
Valiant 40 progress part five, post paint. CharlieCobra Gear & Maintenance 4 05-09-2010 09:15 AM
Single part mono urethane Epifanes paint.. quesiton ,, thoughts Jasper Windvane Sailboat Design and Construction 20 11-28-2009 10:14 PM
Question about Deck Painting Procedure for 2 part paint??? 66luders Gear & Maintenance 13 08-24-2007 08:12 AM
2 part polyurethane paint mikehoyt Gear & Maintenance 1 11-23-2001 07:20 PM
SEO by vBSEO 3.6.1
