Blister repair prep - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 09-23-2012
SchockT's Avatar
Re: Blister repair prep
Originally Posted by WDS123 View Post
The best method is to use a hose and plenty of water - FYI you are not trying to 'dry' out the area from water, although drying is the term people use. Google blister causes
SchockT - #101 had blisters ?
No, I have never found a single blister on my Santana! It is a very well laid hull!
The boat I had blisters on was my Hotfoot; a trailer boat that I was keeping in a slip.
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #12 of 15 Old 09-23-2012
Do nothing at all about blisters. Instead read David Pascoe's articles on the subject. All blister fixes make the non-problem worse allowing more moisture to be drawn along the exposed fibers. At worst, blisters are a cosmetic issue. Attempts to fix them ussually result in more damage than the blister.
Been there, done that, regretted it.
Frogwatch is offline
post #13 of 15 Old 09-23-2012
SchockT's Avatar
I don't see it. How could leaving the pocket of water inside the laminate layers be better than eliminating the water and filling the void? Perhaps a poor repair job could make things worse, but repaired correctly it certainly won't!
From a performance perspective blisters are more than cosmetic. If the hull isn't fair it isn't fast! I know many cruisers don't care how lumpy their bottoms are, but some of us have higher standards than that!
Hull#101
SchockT is offline
post #14 of 15 Old 09-24-2012
ALL blister repairs make matters worse (or at least most). It is not possible to "dry" the hull because ti really isn't wet. The blisters are filled with "gunk" that is hydrolyzed resin that does not really dry. Attempting to repair them simply opens more pathways for water to wick into the gelcoat and hydrolyze more.
Blister repair is one of boatings biggest scams.
RonRelyea likes this.
post #15 of 15 Old 09-24-2012
Seņor Member
PorFin's Avatar
Frog,
While I respect your opinion, I don't happen to agree with you in everything you've said.
Think about the chemistry and physics for a moment. The hydrolyzed resin is mildly acidic. Left alone, it will continue to hydrolyze increasing amounts of cured resin. This is akin to a very slowly growing cancerous tumor within your body.
When filling opened up blisters, almost everyone recommends using epoxy. Epoxy is not water permeable. The schedule is a wet-out with epoxy, followed by applications of thickened epoxy. The choice of thickener is also important -- a non-absorbent filler like Cab-o-sil is the way to go. Deeper repairs should include use of cloth (bi-axial is a good choice in many cases.) Once the area is faired, another coat or two of epoxy to seal the repair.
Most solutions for blistering also include application of an epoxy barrier coat, either over the top of the repaired area or better yet, the entire hull.
When done properly, a repair is pretty much impregnable to water.
However, if corners are cut and a few steps ignored, or inferior products are used then you are destined for future work.
PorFin is offline
blister repair -- advice needed pegasus1457 Gear & Maintenance 12 01-26-2008 01:21 PM
Blister Repair TXS-ALAMO Gear & Maintenance 0 09-05-2007 03:24 PM
Rudder repair, blister & more Burnsy Gear & Maintenance 0 03-07-2004 06:46 PM
Blister Repair Advice Needed petegovoni Gear & Maintenance 2 04-18-2002 12:02 PM
Blister Repair tmichael3 Gear & Maintenance 4 11-30-2001 01:33 AM
