Engine runs today--dies tomorrow - SailNet Community
 2Likes
  • 1 Post By painkiller
  • 1 Post By dabnis
post #1 of 8 Old 09-25-2012 Thread Starter
I am having problems with my westerbeke century 120 hp.. After bleeding the fuel system. The engine runs fine for hours but the next day it will only run for 5 minutes or so .Emptying the racor.. Prime it again, runs for hours and then the next day the same thing.. I have replaced all filters, checked for blocked fuel tank vent, loose fittings on all hoses, switched fuel tanks, checked o-rings on racor, swithced to other filter on dual racor and the same happens everytime.. I cannot think of anything else to try.. Help
sidsail is offline
post #2 of 8 Old 09-25-2012
Junior member, rest old
msmith10's Avatar
Re: Engine runs today--dies tomorrow
That's a big engine! Either a very large boat or a MacGregor.
Mark Smith
1977 C&C 30 Mk 1 hailing from Port Clinton, Ohio
msmith10 is offline
post #3 of 8 Old 09-25-2012
Apropos of Nothing
painkiller's Avatar
Here's what I recommend: Go sailing today. Don't tomorrow.
CalebD likes this.
painkiller is offline
post #4 of 8 Old 09-25-2012
Maybe an air leak downstream of the dual Racors. If you can pressurize the system with an electric pump right out of the tank the air leak may become a fuel leak which should be visible?
The Diesel Page, Electric Lift Pump and Racor Filter installation
Or, you may have a hose that is collapsing inside? Possibly replace all hoses, starting downstream of the Racors?
Paul T
jimrafford likes this.
dabnis is offline
post #5 of 8 Old 09-25-2012
Gene T's Avatar
Paul beat me to it. Good advise. A collapsed hose will stop fuel, cause a vacuum and air will get in somewhere, thereby creating the need to bleed the system. Looks like an air leak but in reality is a collapsed hose. Probably the hose from the tank selector to the Racors.
Gene
Currently in Long Beach, CA
Gene T is offline
post #6 of 8 Old 09-25-2012
travlin-easy's Avatar
I suspect there's a small air leak - just as others have posted.
Good luck,
Gary
travlin-easy is offline
post #7 of 8 Old 09-27-2012
I would be tempted to run a pressurised fuel system.
Stewart Warner make some good electrical fuel pumps.
Rockter is offline
post #8 of 8 Old 09-27-2012
MMR
MMR's Avatar
Send a message via AIM to MMR
We had a Westerbeke that had a similar problems off and on. We discovered, over the course of several years owning that boat:
-Loose electrical connection to the fuel pump (discovered this when we were replacing the fuel pump on the guesstimate that it was bad)
-Bad solenoid
-Misplaced gasket on one of the filters, leaking air into the system
Good luck. Frustrating as all get out!
MMR is offline
Trailering a 3 ton boat without an engine tomorrow itsaboat General Discussion (sailing related) 16 12-19-2011 05:22 PM
Forgot To Tell You Fred Has A Race Today And Tomorrow Giulietta General Discussion (sailing related) 32 11-16-2008 09:35 AM
Fred is online today and tomorrow Giulietta General Discussion (sailing related) 10 11-08-2008 08:13 PM
Today & Tomorrow in BOSTON : 16/Sep - Challenge Transat 2006 - Leg NewsReader Mass Bay Sailors 0 09-16-2006 11:15 AM
