Anyone have their davits set up for one person to use? - Page 2 - SailNet Community
 3Likes
post #11 of 12 Old 11-01-2012
Old as Dirt!
svHyLyte's Avatar
Re: Anyone have their davits set up for one person to use?
One can implement a single line lift by using a spreader bar slightly longer than the distance between lift points on the boat at the level of the boat. The slings attached to the boat are connected to the spreader bar fore'n aft at the lift points. A (multi-part) lift line is attached to the motor end of the boat with the line led over a block at the davit and back to the block at the spreader bar, then along the length of the spreader to a single block at the forward end of the boat above the forward slings, around that 90º and up to a single block at the second davit and from there, through lead blocks, through a cam-cleat and to a convenient winch or horned cleat. Assuming one has to lift a combined weight (motor and boat) of 200#, a 5:1 tackle at the aft davit would require only 40# of tension in the lift line. Because of the spreader bar, both ends of the boat must raise at the same rate. If the foregoing is unclear, I can make a sketch but it's really not complicated.
FWIW...
svHyLyte is offline
post #12 of 12 Old 11-01-2012
chef2sail's Avatar
It is an advantage to have the capabilty to have the lines seperated when lifting or lowering so you can put a slight angle to let any excess water go out the drain hole before placeing the plug in. The main thing here is the proper purchase. Ours is 6:1 so lifting 140 lbs is fairly easy.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
Another new person t_train Introduce Yourself 1 09-11-2012 06:14 PM
Am I the only person here... JaredC General Discussion (sailing related) 4 02-04-2011 08:53 PM
Im a very mean person........ SVDistantStar General Discussion (sailing related) 3 09-19-2008 03:03 PM
RIB on 32' davits rfortenbaugh Ericson 1 07-04-2006 07:10 PM
davits ehmaxey Gear & Maintenance 3 02-18-2003 10:37 AM
