Anyone have their davits set up for one person to use? - SailNet Community
 3Likes
post #1 of 12 Old 09-26-2012 Thread Starter
Closet Powerboater
MedSailor's Avatar
My current davit setup is "temporary" to say the least. I would post a photo but then I would loose what shreds of brackish credibility I may have here. My problem with half-measure temporary fixes is that sometimes they work and when they do, I'd rather go sailing than spend the day fixing them... My sailing season has likely come to an end this year so I can now focus on projects.
My current davit setup, and planned future upgrades, are pretty standard. Two stainless arms, some pulleys on each, and TWO ropes to lower the tender. Problem is that it takes two to lower or raise. I "could" raise or lower the tender by doing it 3 feet at a time on each side and cleating off each side, but that's not quick nor easy.
Anyone have suggestions for making the davits solo-friendly?
MedSailor
MedSailor is offline
post #2 of 12 Old 09-26-2012
chef2sail's Avatar
Re: Anyone have their davits set up for one person to use?
I singlehand a lot and use the dinghy from davits. I do one side at a time half the way then switch sides, not really inconvenient at all. Most of thr time I pullthe dinghy up even with the wife on board. Have Garhauer 11/4 tubes with 6x1 purchase. Cam cleats after the blocks so i can lovk on side easily beore pulling the other. Quite easy actually.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #3 of 12 Old 09-26-2012
I swap side to side as well. Three stages on each side. For the end of the dinghy with the motor, I bring the line back to the primary winch on that side. I can pull up the bow by hand.
Jeanneau 54DS
Minnewaska is offline
post #4 of 12 Old 09-26-2012
Señor Member
PorFin's Avatar
It's usually a one-person job here as well (and you know who is that one person...)
Cam cleats make all the difference.
PorFin is offline
post #5 of 12 Old 09-26-2012
Maine Sail's Avatar
It's always a one person job for me but we have cam cleats for the davit lines... Going up I do port then stbd then port then stbd. Going down I can hold and deploy both port and stbd lines at the same time...
chef2sail and jimrafford like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 12 Old 09-26-2012
chucklesR's Avatar
I do the side to side dance -
The only way I could see doing away with the dance is to put a turning block on the davits and another amid ships, they would need guide blocks/eyes as well.
By the time you get done doing that you'd have so much induced friction you'd likely need a winch as well - and the lines would have to be of equal length (not likely).
You could rig a four point hoist onto the dinghy and connect to a single lift line (like some trawlers do), but you better eat your wheaties because that's going to be a heck of a pull to get a dinghy up (e.g., my 115 pound RIB and it's 50 pound motor).
chucklesR is offline
post #7 of 12 Old 09-26-2012
pdqaltair's Avatar
Lowering. Easy, just stand in the middle and hold both lines.
Raising. Side to side. Really, it would be a lot of weight to do at once, which would mean more tackle and more friction, or winches.... and not easier. Because the blocks swivel and have cam cleats, I don't have to walk side to side, only pull right, pull left, pull right.... And there's no harm in lefting a few feet at a time.
As everyone has suggested, a 6:1 tackle and cam cleats is the way to go. So easy my girl could manage it when she was 13.
Sail Delmarva: Better Purchase for Dingy Davits
redline likes this.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #8 of 12 Old 09-26-2012
Yes, cam cleats here as well as two horns on the top of the davit.
Jeanneau 54DS
post #9 of 12 Old 10-24-2012
beachbm61's Avatar
I'm always the one raising the dinghy by myself. I've got a 4:1 purchase. Should have gone with 6:1 so the lady could do it by herself.. I normally pull both lines at the same time. Our dink is a light Mercury RIB with a small 2 stroke 6hp Merc.
beachbm61 is offline
post #10 of 12 Old 11-01-2012
redline's Avatar
Thanks for the mention of checking the Harken site for the 90-degree reeving of the 6:1 tackle. I upgraded from 4:1 to 6:1 when I change to a 15Hp outboard on our 3.1m RIB, and however I rigged it (same as all the other boats I saw with triple blocks), there was always a high-friction crossover.
One caveat: the Harken drawing looks wrong on the webpage,
Harken Reeving Diagrams
(the line on the becket crosses in front two others), but clicking "print version"
http://www.harken.com/pdf/6-1_reeving-diagram.pdf
gives a much clearer and correct view.
Oh, and I also hoist from the center, alternating sides. I can start pulling both lines together, but once the aft end is out of water, no way.
Norman
s/y "Redline"
1998 Jeanneau SO45.2
Last edited by redline; 11-01-2012 at 10:25 AM. Reason: vote for alternating sides
redline is offline
Another new person t_train Introduce Yourself 1 09-11-2012 05:14 PM
Am I the only person here... JaredC General Discussion (sailing related) 4 02-04-2011 07:53 PM
Im a very mean person........ SVDistantStar General Discussion (sailing related) 3 09-19-2008 02:03 PM
RIB on 32' davits rfortenbaugh Ericson 1 07-04-2006 06:10 PM
davits ehmaxey Gear & Maintenance 3 02-18-2003 09:37 AM
