External fuel tank air vent - SailNet Community
post #1 of 5 Old 09-27-2012 Thread Starter
I've got a 6HP Nissan with an external tank. The manual says to close air vent when the engine is stopped. The concern I have is with the pressure that builds up in the tank with the air vent closed. What do you recommend while the boat is moored/docked/underway?
jfine is offline
post #2 of 5 Old 09-27-2012
RichH's Avatar
Re: External fuel tank air vent
When stored, you keep the tank vent closed to prevent the absorption of atmospheric water into the fuel; keep the tank in a shaded place out of the sun to lessen the build-up of tank pressure.
Long term heat/pressure build up inside these rotomolded ext. tanks will eventually destroy the tank .... @ ~$70.00 per 3 gal tank. If you store these on deck, get or make a 'suncover' to help shade them, etc.
Best is to not long term store any fuel in these 3 gal. tanks; but rather, dump the unused fuel into your automobile and store the tank empty and with the vent valve open. Gasoline only has a shelf life of 30-45 days without stabilizer, a little bit longer with stabilizer. Empty tanks dont need stabilizer.
RichH is online now
post #3 of 5 Old 09-27-2012 Thread Starter
Thank you for the amazingly quick response RichH. I hadden't thought of the water aspect and it makes perfect sense. The external tank is stowed under the port locker so it's out of direct sunshine. This is our first sailboat so naturally we're learning as we go. I plan on yanking as much out of the boat as possible for winter storage, including the fuel tank, and will dump whats left after the season into the sacrificial lamb, er my lawn tractor.
jfine is offline
post #4 of 5 Old 09-27-2012
The latest tanks (as of last year, I think) have a pressure relief valve at 5 PSI. So most of the time they stay sealed, unless you leave it out in the sun when the valve will vent the excess.
Note that they also tell you to leave an air gap when filling, this allows for the fuel to expand without creating excess pressure. That's why the tanks are 3.2 gals but the max fill line is at 3 gallons, for example.
MarkSF is offline
post #5 of 5 Old 09-27-2012 Thread Starter
Great, thanks MarkSF. I've learned my lesson from overfilling some 5 gal tanks in my garage. ;-) This is a '08 that was bought in '10 so I'm guessing the tank was produced somewhere in there, although I'll only be able to check once I'm back on board.
jfine is offline
GS 39 Fuel Tank Vent Line camndon Gulfstar 7 10-16-2013 06:32 PM
Understanding fuel and e10 gasoline tank vent driers pdqaltair Gear & Maintenance 19 02-06-2012 08:59 PM
Diesel Fuel Tank Fill & Vent casey1999 Diesel 12 04-20-2011 12:57 PM
Fuel Tank Vent Filter trlrtrsh Boat Reviews 14 04-13-2011 04:14 AM
location of fuel tank vent sailhog Gear & Maintenance 6 07-29-2007 01:21 PM
