cracks in the bilge - SailNet Community
post #1 of 12 Old 09-27-2012 Thread Starter
davidpm's Avatar
cracks in the bilge
What do you think these cracks represent:
Beneautu 32s5
2012-09-27_13-34-05_937 (Small).jpg   2012-09-27_13-34-13_355 (Small).jpg   2012-09-27_13-34-40_667 (Small).jpg   2012-09-27_13-35-02_888 (Small).jpg
davidpm is online now
post #2 of 12 Old 09-27-2012
TQA
Bombay Explorer 44
TQA's Avatar
Re: cracks in the bilge
Time to call in a pro methinks. Could well be serious.
Have you hit anything with the keel or been bounced on the bottom?
TQA is offline
post #3 of 12 Old 09-27-2012 Thread Starter
davidpm's Avatar
Came ashore a few days ago.
post #4 of 12 Old 09-27-2012
Agree time to call in a pro...and insurance co.
If by any chance boat is back in water without addressing issues
I would monitor by putting a piece of masking tape across areas and after a few tacks you will get an idea of flexing/movement
if tape broken. Sadly I think will need to be addressed first.
HUGOSALT is offline
post #5 of 12 Old 09-27-2012
Marcel D's Avatar
That would be your keel flexing back and then foward again not good. If you see those kind of spider cracks you usually get these in high flex areas in the **** pit from flex. The only reason you would get these at the thickest part of hull is a sudden stop. Also be warned all of the pictures you have taken are of the hull grid liner bonded to the hull you realy have no idea what the hull looks like below the grid. I agree with these guys get her hauled and get pro too look at her and then contact you insurance company.
Marcel D is offline
post #6 of 12 Old 09-27-2012
Tartan 27' owner
CalebD's Avatar
I dunno. None of what you seem to be calling cracks looks new. Hard to tell with all that dirt in there. Clean it up, keep an eye on it. I like the idea of using masking tape to see if it is flexing once back in the water. Better still, clean it up, coat it with a layer of fresh gel coat and see how quickly the cracks return.
I'd be more concerned about the area where the keel bolts are, if there are any. Is the keel encapsulated or bolted to the hull?
Also, that boat has a few years on it and has probably run aground before in LI Sound. Granted, running up on the beach as it did probably stressed the keel/hull joint more then a light grounding.
You can always call Beneteau and get their opinion. Brad calls them often enough.
If I worried about every crack on my 45 year old hull I'd have no hair left. I still have plenty.
Note the vague similarity between these two photos.
Everybody has one:
CalebD is offline
post #7 of 12 Old 09-27-2012
Marcel D's Avatar
So was the dog stearing at the time you might want to keep that away from the insurance company
Marcel D is offline
post #8 of 12 Old 09-28-2012
Aspiring to be a Mexican
sww914's Avatar
Big deal in my opinion.
sww914 is offline
post #9 of 12 Old 09-28-2012
chef2sail's Avatar
His boat broke free from a mooring in high winds and a particular strong song and beached its.
I would have them looked at. Maybe just over the years stuff, or maybe serious structural cracks which will compromise the keel staying attached to the boat. Were the cracks always there or just appeared after the beaching?
That answer will really tell you what to do.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #10 of 12 Old 09-28-2012
Senior Smart Aleck
jameswilson29's Avatar
Damage from being beached and pulled off. The good news is damage from a casualty, as opposed to wear and tear, should be covered by your insurance.
jameswilson29 is offline
J24 Bilge Cracks mnky Gear & Maintenance 31 05-15-2012 12:28 AM
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Santana bilge stress cracks larlei Gear & Maintenance 1 09-07-2009 11:49 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
cracks on eck richb Boat Review and Purchase Forum 1 08-16-2001 01:47 PM
