Teak stain issue - Page 2 - SailNet Community
post #11 of 12 Old 10-03-2012
Re: Teak stain issue
If you get anywhere close with stain removal stop. It is very easy to overdo it and then it looks worse than the original stain. Wipe the whole piece with mineral spirits and you can get an idea of what it will look like finished but the spirits will evaporate quickly and leave you with a clean surface. If you have found varnish on the wood it will need to be stripped completely. If it was only oiled you can build up oil coats to try and match the joint between old and new and then re oil the whole piece.
rbrake is offline
post #12 of 12 Old 10-03-2012
Forgot to add that sun will do a lot over time to blend in the discoloration at the meeting places and with the rest of the wood.
rbrake is offline
Stain to match TEAK stpabr Gear & Maintenance 5 12-06-2010 06:16 AM
teak water stain xort Gear & Maintenance 3 06-01-2008 10:52 PM
Wife wants darker teak stain??? gwp Gear & Maintenance 5 05-25-2008 08:48 AM
stain teak rails mroskothen Gear & Maintenance 3 07-26-2003 06:15 PM
Diesel Stain in Teak Veneer vikinglady herSailNet 1 07-22-2001 10:35 PM
