Spinnaker sock: North or ATN - SailNet Community
post #1 of 6 Old 10-02-2012 Thread Starter
jsaronson's Avatar
I want to buy a spinnaker sock. I've used the ATN but the sock from North Direct is less expensive. Has anyone used the North? Any issues with either?
jsaronson is offline
post #2 of 6 Old 10-02-2012
Senior Smart Aleck
jameswilson29's Avatar
Re: Spinnaker sock: North or ATN
Are you sure you need a spinnaker sock, Joel?
I have been launching and dousing my symmetrical spinnaker solo without a sock. As long as the jib is up blocking the wind, it works fine. Dousing under the boom into the companionway by pulling the sheet works great - no problems as long as I release the guy, then the halyard.
I store and launch my smaller spinnaker from a Target laundry basket, secured with bungee cords (seen here on deck):
I store and launch my larger spinnaker from a traditional turtle, which requires a bit of pulling to extract while pre-feeding the guy.
jameswilson29 is offline
post #3 of 6 Old 10-02-2012 Thread Starter
jsaronson's Avatar
Jim, Yes a sock is a convenience, not a necessity. I'll get more use out of the asymm with a sock. The North Direct is only $350 or so, so given what I have put into the boat, its a rounding error. Great to see you are getting a lot of use and enjoyment out of the Pearson. She was a great boat before your upgrades!
post #4 of 6 Old 10-02-2012
rhr1956's Avatar
I have a ATN for sale. Ordered it in June from Sailrite. Used it once and it worked fine. It is 30' 2". Will that work for you?
rhr1956 is offline
post #5 of 6 Old 10-02-2012 Thread Starter
jsaronson's Avatar
Sorry, I need something in the 41 foot range.
post #6 of 6 Old 10-02-2012
Senior Moment Member
SloopJonB's Avatar
The North sock uses an injection moulded bell while the ATN uses a Kevlar laminated bell. I imagine that is the basic reason for the difference in price. AFAIK the ATN still sets the standard for snuffers.
Check the used sail sites on the web - they frequently have ATN's very cheap, some near new as a lot of people decide they don't like using a snuffer.
SloopJonB is offline
Tags
atn , north , spinnaker sock
Do I need a spinnaker sock? kwaltersmi Learning to Sail 20 10-22-2009 01:21 PM
Spinnaker Sock ERICANDERSON Gear & Maintenance 6 10-04-2009 12:23 PM
Spinnaker sock jarcher Racing 1 05-06-2009 05:41 PM
Need a spinnaker sock - 35' ByronJ Gear & Maintenance 0 04-13-2009 12:01 AM
Spinnaker with sock... eMKay Learning to Sail 14 05-23-2008 07:30 AM
