Like Tree3Likes
  #11
Old 10-03-2012
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
Re: Advice on removing snapped s/s bolts from alu block
stainless can usually be drilled using a lot of pressure & slow RPM.
Liberals are people who care about others. Freethinkers are not constrained by the myths of religion.
  #12
Old 10-03-2012
sailordave is on a distinguished road
Couple of things you want to do.
First heat it very slowly w/ a propane torch. Do NOT use a MAPP torch (too hot) Don't get it so hot it turns color, just heat it up.
Take a ball peen hammer and tap gently all around the broken off piece. Spray some PB blaster or other type "stuff" on it. Tap some more.
Let it cool a bit and then try using a LEFT hand twist drill bit. You'll need a cobalt bit to drill into the SS. Start w/ a smallish bit and after you get some depth, go back and use a slightly bigger bit. If you're lucky the drill bit will grab and twist it out. More than not however, you'll have to drill enough to get an easy out in.
Keep heating and cooling. The difference in the metals may eventually let it break free.
Nothing wrong w/ using SS and AL. Just need to make certain you smear some TEFGEL on the fastener to isolate the metals from each other.
CS 36M DIANTHUS
  #13
Old 10-03-2012
Geoff54's Avatar
Geoff54 is on a distinguished road
You have lots of suggestions - which ones might work really depends on the exact circumstances. If you try to drill it out invest in some left handed drill bits.
There is another alternative that save my as* a few times, including the time I snapped off an extractor, inside a hardened stud, inside a magnesium casting. It's called spark-erosion and works just as the name suggests.
It's not cheap and there aren't many places that do it (I only knew of one in the LA area when I lived there) but if you can find one locally, it's the best way to go for difficult extractions.
If you can't find anyone, ask around old fashioned motorcycle shops, classic car/motorcycle restorers, machine shops that rebuild engines (especially exotic engines), etc.
Good Luck
  #14
Old 10-03-2012
Brewgyver's Avatar
Brewgyver is on a distinguished road
Another quick note. If you're going to try this yourself, the biggest problem with drilling is that the screw is frequently broken off unevenly, and the drill bit will walk right off of it. Use a center punch (a real center punch, not a nail, not a nail set) to dimple the exact center of the screw.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
  #15
Old 10-03-2012
Sea Dawg is on a distinguished road
Sailordave has it right, except MAPP fuel may be necessary if the aluminum carries too much heat away. YOu want to get it pretty toasty and spray the PBbuster on while it's hot and the quick shrinkage can create more crevice between the bolt and threads. Also, the center punch is necessary which can also shock the bond between the threads. Lastly, there is a impact driver that will transfer hammer blows into rotation and doesn't cost much to try. You'd have to chisel a flat head slot to get a grip. Heat, cool, shock, repeat. IT will come out.
  #16
Old 10-03-2012
TQA's Avatar
TQA TQA is offline
Bombay Explorer 44
TQA is on a distinguished road
hEAT IS GOOD.
  #17
Old 10-04-2012
MarkSF is on a distinguished road
Thanks everyone, I have all the tools on order, so I'll try it when they arrive (reverse drills, extractors, hole punch, etc)
Bristol 31.1
  #18
Old 10-04-2012
wduncan50's Avatar
wduncan50 is on a distinguished road
You might try this from Loctite: Welcome to: Loctite® Freeze & Release
I don't know if it works but I know I tried heat once on a SS bolt in a traveler (alum) and still broke the bolt after heating and spraying with PB several times over a couple of days.
davidpm likes this.
Will Duncan
  #19
Old 10-05-2012
tommays's Avatar
You pretty much screwed yourself not using heat and patience in the initial tear down don't screw your self up even worse learning to drill out small SS bolts on something that will become JUNK if you get wrong as there is NO room for error
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
  #20
Old 10-05-2012
Sal Paradise's Avatar
Sal Paradise is on a distinguished road
I have experience with this. You will have to drill the old bolt out starting with a very small bit.Use titanium bits. For an M6 get 3 bits the largest bit the same size as the bolt. Then get a NAPA helicoil kit. It includes a special size drilland tap. It will be easier than you think, just follow the directions. You thread the helicoil into the new threads and then use a new bolt. Motorcycle mechanics know all about this. Its a very common repair. I have done this and it works.
Easy Outs are crap and don't work!
You may post attachments
You may edit your posts
Advice on glassing in wood keel spacer block bigwalt Gear & Maintenance 35 04-10-2011 07:21 PM
snapped coaxial cable for SSB yzlian Gear & Maintenance 13 03-09-2011 01:15 PM
Mast snapped 12/09/09 crane0730 General Discussion (sailing related) 4 12-13-2009 04:44 PM
removing a thru-hull, any advice? RetCO Newport 5 12-03-2009 07:06 PM
Chain Plate snapped Update. ktucker8 Gear & Maintenance 0 09-06-2006 06:53 PM
SEO by vBSEO 3.6.1
