Advice on removing snapped s/s bolts from alu block - Page 4 - SailNet Community
 3Likes
post #31 of 36 Old 10-05-2012
flyingriki's Avatar
Re: Advice on removing snapped s/s bolts from alu block
Originally Posted by chucklesR View Post
Use a dremel and cut a groove for a flat head screw driver, soak it in PB Blaster or the lube of your choice then back them out with a hammer drill.
+1.......worked for me on almost every screw on my boom....
flyingriki is offline
post #32 of 36 Old 10-06-2012
Aspiring to be a Mexican
sww914's Avatar
Heat, impact, PB Blaster.
sww914 is offline
post #33 of 36 Old 10-06-2012
HANUMAN
RobGallagher's Avatar
PB Blaster is great. This might be better.
Google Deal
RobGallagher is offline
post #34 of 36 Old 10-06-2012
Google Deal
oh yeah, +1!
Sea Dawg is offline
post #35 of 36 Old 10-08-2012
Mark, fastest cheapest best result might be to just find a good machine shop, let them deal with it. If the machinist has any doubts, find a better shop.
PBlaster is great stuff, it chemically attacks the corrosion. So does Kroil--but you have to mail order that.
Torches are nice but can weaken the metal. A CO2 extinguisher or small tank of CO2 from a gas shop can do the same thing by freeze-soaking the parts. Slotting the bolt with a Dremel and using an impact hammer is also good, I'd try the PBlaster and freeze cycling it 3-4 times before whacking away at it, in that sequence. And if none of that worked, THEN center punch it and carefully drill out as much as you can. In the worst case, you overdrill and use Heli-Coils. But a good machine shop can put that engine in a drill press and chew the studs out, or they can weld a crossbar onto them and then just spin them out.
I'm going to guess they'll get rid of the bolts for under $50, as opposed to screwing around all afternoon worrying about it. Hardest part of the job would be finding a good machine shop.
hellosailor is offline
post #36 of 36 Old 10-08-2012
I've had this exact problem. I've tried most of the solutions posted here, including an oxy-mapp torch.
The thing that worked in the end: an arc welder.
There's corrosion between the bolt and the surrounding aluminum. It's frozen in place.
The current from the welder broke it free in under a second.
Take it to a shop with a welder. Ask them to pull the bolt.
1975 Tartan 30 Competition Rig
eko_eko is offline
Advice on glassing in wood keel spacer block bigwalt Gear & Maintenance 35 04-10-2011 07:21 PM
snapped coaxial cable for SSB yzlian Gear & Maintenance 13 03-09-2011 01:15 PM
Mast snapped 12/09/09 crane0730 General Discussion (sailing related) 4 12-13-2009 04:44 PM
removing a thru-hull, any advice? RetCO Newport 5 12-03-2009 07:06 PM
Chain Plate snapped Update. ktucker8 Gear & Maintenance 0 09-06-2006 06:53 PM
