Help! Refinishing Interior Teak - SailNet Community
post #1 of 8 Old 10-03-2012 Thread Starter
leogallant's Avatar
Hi all you teak refinishing experts!
I'm wondering what will be the best type of finish for teak cabinets below decks. I'm refinishing them in my shop then reinstalling in my boat. Cabinet boxes, frames, doors, drawer fronts, etc...
Varnish, and what type, or something else?
Not sure I want to just oil it, but its an option too...
Thanks!
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
post #2 of 8 Old 10-03-2012
Sailor
Gladrags1's Avatar
I used Dalys Seafin as a topcoat on my boats teak. Glossy but not too much plus a hard finish. Test it on inconspicuous spot as I applied it over previously refinished teak and new teak plywood to see if you like it.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
post #3 of 8 Old 10-03-2012
Tartan 27' owner
CalebD's Avatar
Re: Help! Refinishing Interior Teak
Leo,
For cabin bright work you should really be able to use a wide range of finishes, including varnish, oils and even polys. The cabin bright work does not have to stand up to the scourge of constant sun and moisture like your outside wood does.
Asking what brand of varnish is best is like asking what flavor ice cream people like. Out of 20 people you are likely to have 20 + answers.
I'll give you an example: I have used Interlux Schooner varnish. I like the way it smells and it looks nice. I have seen some woodwork done in Epiphanes and it also looks superb. The folks at the Wooden Boat Forum all seem to swear by a French varnish called Le Tonkinoise. I'd recommend all three having only tried one.
Part of your decision should be about what kind of finish you want in your cabin. If you want a matte finish then an oil may be the way to go, if you want a semi-gloss finish then only certain varnishes will give you this. There are quite a few high-gloss finishes you could use.
Ease of maintenance should be another consideration. Oil finishes will require the most maintenance usually. Varnishes should last a good long time in your cabin without much maintenance.
Ease of application or use should be yet another. Oils are easy to apply. Varnish is also pretty easy to use. Urathane finishes like Bristol Finish can be a bear to work with and smell horrible.
Everybody has one:
CalebD is offline
post #4 of 8 Old 10-03-2012
Send a message via Yahoo to dacap06
I like tung oil. It is easy to apply and doesn't bubble. The more coats you put on, the shinier it is.
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #5 of 8 Old 10-03-2012
Senior Moment Member
SloopJonB's Avatar
Since you're doing it at home, I'd recommend REAL hand rubbed varnish. I did mine at home the following way - first coats of thinned gloss varnish then 3 or 4 coats of full strength, block sanding between the last couple with 220. After achieving a good matte 220 finish I went to 400 wet then 600 wet after which I rubbed it out with fine, hand applied automotive rubbing compound.
Lots of work but it came out gorgeous - a soft gloss, much nicer than the "rubbed effect" varnish but much softer than full gloss.
I regard those "rubbed effect" finishes the same way George Carlin did about chocolate food & drink advertizing.
"What does 'rich, chocolatey flavour mean?' - 'no f**king chocolate'".
SloopJonB is offline
post #6 of 8 Old 10-03-2012
Seņor Member
PorFin's Avatar
Leo,
I've been very happy with poly for interior teak. It's nowhere near as demanding to apply well as varnish, and it holds up very well to the bumps and abrasions that typically occur in the cabin.
I used Minwax Helmsman (built the base coats with gloss, then finished with semigloss on most surfaces.) The Helmsman's got a little more body to it so it tends to buld a little faster than Minwax's vanilla poly. There's a little UV protection in the Helmsman as well, but that's not really a major concern below.
PorFin is offline
post #7 of 8 Old 10-04-2012 Thread Starter
leogallant's Avatar
Thanks everyone! Gave me lots to think about! :-)
Leo
post #8 of 8 Old 10-04-2012
remetau's Avatar
We chose Minwax Wipe-On Poly. It provides a very nice finish and you can't get any easier than wiping a finish on.
Don & Diana
sv Re Metau an HC33t
remetau is offline
Refinishing interior teak KenD Gear & Maintenance 9 11-19-2012 07:03 AM
Refinishing Teak jetdrvr393 Gear & Maintenance 32 11-01-2011 12:07 PM
Teak refinishing and repair Waterline Gear & Maintenance 21 06-10-2010 02:21 PM
Refinishing Teak Dan Dickison Gear and Maintenance Articles 0 05-22-2001 08:00 PM
teak refinishing jproctor Gear & Maintenance 3 04-22-2001 05:47 AM
