-   -   Universal M12 Fuel Pump (http://www.sailnet.com/forums/gear-maintenance/92722-universal-m12-fuel-pump.html)
santana30RI 10-03-2012 09:03 PM
For the m12 do you need a fuel pump to run it
H and E 10-04-2012 08:07 AM
Re: Universal M12 Fuel Pump
Mine has an electric fuel pump that I run for a few seconds prior to starting. The engine will start without it but it takes a long time for the fuel to get pumped into the engine. The key switch has a spring-loaded position, similar to a key start, which turns on the electric pump. Starter switch is a push button.
JimsCAL 10-05-2012 08:48 AM
A diesel has two fuel pumps. The high pressure injection pump whick supplies the injectors with fuel and a low pressure pump which supplies fuel from the tank to the inlet of the injection pump. The low pressure pump can be either electric or mechanical. Note that if the fuel tank was located above the injection pump, the head could be enough to supply fuel to the injection pump without a low pressure pump.
Stu Jackson 10-06-2012 12:59 PM
An electric fuel pump will make bleeding your engine much, much, much easier.
