Diesel Additives - SailNet Community
 1Likes
  • 1 Post By dabnis
post #1 of 10 Old 10-04-2012 Thread Starter
Diesel Additives
Wondering is anybody uses diesel additives in their sailboat fuel tank. I was in an autoparts center and saw a row of 'marine' variants claiming biocide, injector cleaning, reduced emissions, etc. Considering I use maybe 6-7 gallons a year, and top up every couple of years, I am not sure if there would be any value in them for me, but thought I would ask....tx.
paul323 is offline
post #2 of 10 Old 10-04-2012
Re: Diesel Additives
I use an FPPF product '8+ Cetane Improver'..OK'd by Mack Boring when I toke their diesel course
aa3jy is offline
post #3 of 10 Old 10-04-2012
dabnis is offline
post #4 of 10 Old 10-04-2012
I am always sure to have biocide and fuel stabilizer in my tank. At least one brand of fuel comes with it and adding more is ill advised. In fact, it's a common mistake that boaters add too much.
Just this season, for the first time, I used a cetane booster. The advertised dose can be doubled safely and I did so. I actually noticed a difference in exhaust, power and responsiveness. For the little fuel we burn, I think it was worth it, but not necessary.
Jeanneau 54DS
Minnewaska is offline
post #5 of 10 Old 10-04-2012
remetau's Avatar
I add Mystery Oil to my oil and diesel.
Don & Diana
sv Re Metau an HC33t
remetau is offline
post #6 of 10 Old 10-04-2012
In addition to a biocide, I use a product called Stanadyne. It's a diesel fuel cetane enhancer as well as lubricant. Used primarily by truckers, it seems to work great and is not a "Marine" product, so is relatively inexpensive. Check out the web site. Home - Stanadyne
mgiguere is offline
post #7 of 10 Old 10-04-2012
chef2sail's Avatar
We use an FPPF product '8+ Cetane Improver' also, plus a small amt of bicide. Just becareful not to overdue as Minnie said. Ask me how I know ( grrrrr)
dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #8 of 10 Old 10-04-2012
davidpm's Avatar
dave
What happened? Just smoke or a ring job. Big difference.
davidpm is offline
post #9 of 10 Old 10-04-2012
Old enough to know better
This is good stuff and recomended by many manufacturers and is popular with the VW and MB crowd.
also Stanadyne is a OE supplier of injectors, and fuel pumps it is designed to not hurt anything in the fuel system.
Sent from my ADR6425LVW using Tapatalk 2
1976 C&C 33
Project boat, lots of work to be done!
miatapaul is offline
post #10 of 10 Old 10-04-2012
youmeandthed's Avatar
I put a bit of Cetane booster in diesel that has sat for a few months. Biocide, and a clean fuel tank keeps the filters and injectors in good shape. Adding a 10% to 20% Kerosene mix will clean your injectors, but make sure not to do it too much and let the kerosene dry out the seals. For the fill up after add a bit of clean engine oil to your fuel, to keep the seals in good shape.
Life's a dream, live it!
youmeandthed is offline
Fuel Additives for Ethanol boardandplunder Atomic 4 10 08-13-2012 08:31 PM
Additives ( a discussion) deniseO30 Diesel 10 05-27-2012 07:05 AM
Diesel fuel lines -Universal 3cyl diesel argofred Diesel 8 04-18-2011 03:39 PM
Auto Diesel vs Marine Diesel / Addatives NewsReader Mass Bay Sailors 0 07-11-2007 06:15 PM
Ultra low sulphur diesel and the older marine diesel Valiente Gear & Maintenance 2 10-20-2006 12:10 PM
