Shrink Wrap - SailNet Community
 3Likes
  • 1 Post By Maine Sail
  • 2 Post By chucklesR
post #1 of 7 Old 10-05-2012 Thread Starter
Shrink Wrap
I live in Nova Scotia and am thinking of shrink wrapping my FG boat this winter. However, someone mentioned today that SW can cause damage to a boat's finish in certain conditions.
Has anyone heard about this or have experience?
Phil
Atlantic Salt is offline
post #2 of 7 Old 10-05-2012
Gene T's Avatar
Re: Shrink Wrap
I have heard that SW can damage painted surfaces. I have no personal experience with it however, but a friend lived aboard in Connecticut would build an enclosure above deck using SW over a frame. He even had a door. But he did not SW the hull or any painted parts.
Gene
Currently in Long Beach, CA
Gene T is offline
post #3 of 7 Old 11-17-2012
Re: Shrink Wrap
I'm a DIY user of shrink-wrap and have overheated it against my Petit Easypoxy painted hull. The plastic melted tight in a smear on the hull, but then peeled off in the spring. After several seasons of the same mistake in the same place, the plastic is getting harder to peel off, but it hasn't left a permanent mark. It's easy to overheat the stuff. In one harbor, there was a nearby coal burning factory and the nearly invisible soot would settle on the SW and then burn thru when I applied the flame to shrink the stuff. I leave the ends open, using the mast as a ridge pole.
SailingSloop is offline
post #4 of 7 Old 11-19-2012
Maine Sail's Avatar
Re: Shrink Wrap
Phil
With painted finishes eg: Awlgrip or similar water trapped between the cover and hull can cause it to blister and ruin the finish. When shrinking a gelcoat boat moisture already in the hull near the waterline can flash to steam and pop little blisters off near the waterline. Wal around any yard that does shrink wrap and you see a few of these boats with waterline blisters. Personally I choose not to shrink wrap over the hull and would stop at the toe rail, as I do on my own boat...
kwaltersmi likes this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #5 of 7 Old 11-19-2012
chucklesR's Avatar
Re: Shrink Wrap
for a couple years worth of shrink wrap you can get a 20 year cover.
It goes a foot down to protect the teak rub rails
chucklesR is offline
post #6 of 7 Old 11-19-2012
Broad Reachin'
kwaltersmi's Avatar
Re: Shrink Wrap
I agree with others, between the heat gun and potential for moisture to get trapped against topside paint/finishes, shrink wrap can damage a boat. However, I've never had a problem if it's done carefully and properly. I've found that air vents are critical.
Catalina 34
kwaltersmi is offline
post #7 of 7 Old 11-19-2012
Learning the HARD way...
eherlihy's Avatar
Re: Shrink Wrap
The problem with most 20 year canvas covers - at least here in the Northeast, and Nova Scotia, is that snow can build up on top of the cover (sleet freezes to the cover) and increase the weight on the cover, and therefore increases strain on the stanchions.
The nice thing about the way that your boat is covered, Chuckles, is that the cover does not go over the stanchions, but rather attaches at the base.
eherlihy is offline
Shrink wrap Dougblowboat SailNet FAQ 8 05-05-2011 11:22 PM
shrink wrap NewsReader Mass Bay Sailors 2 05-05-2011 11:10 PM
Shrink wrap vs. Tarp labatt Gear & Maintenance 37 05-05-2011 07:19 PM
would it be possible to reuse "shrink wrap" / shrink wrapping yourself q's purvisgs Gear & Maintenance 8 04-11-2008 10:35 PM
Shrink wrap around shrouds? labatt Gear & Maintenance 25 11-09-2007 09:33 PM
