Like Tree9Likes
  #1
Old 10-05-2012
anerussis's Avatar
anerussis is on a distinguished road
Question Keel bolt torque values ????
After reading some postings suggesting that the keel bolts should occasionally be re-torqued I decided to do just that on my recently acquired 1977 C&C 26.
There are several 1/2" nuts and 1- 1/2" nuts on the keel bolts. I used my breaker bar on the 1/2" nut expecting a battle but was able to quite easily tighten it at least 1/2 a turn. I did not attempt to tighten the rest fearing that I may cause more damage then good and possibly break the seals causing leaks.
Does anyone know the torque values for these 1/2" and 1 1/2" nuts or does one just tighten by feel which would of-course very by the size and strength of the individual.
Years from now you will be more disappointed by the things you didn't do than the ones you did do.
~Mark Twain
  #2
Old 10-05-2012
RobGallagher's Avatar
HANUMAN
RobGallagher is on a distinguished road
Re: Keel bolt torque values ????
There are several 1/2" bolts and 1 1/2" keel bolts. I used my breaker bar on the 1/2" bolt expecting a battle but was able to quite easily tighten it at least 1/2 a turn. I did not attempt to tighten the rest fearing that I may cause more damage then good and possibly break the seals causing leaks.
Does anyone know the torque values for these 1/2" and 1 1/2" bolts or does one just tighten by feel which would of-course very by the size and strength of the individual.
CNCphotoalbum.com has torque values listed by bolt size.
  #3
Old 10-05-2012
anerussis's Avatar
Yes I saw that but it does not list 1-1/2 " bolts --- It show 80 lbs for 1/2" and 450 lbs for 1 1/4 bolts - but would that apply to all keel boats large and small - 18 ft to 40 ft + boats?
Feel a bit dumb but just realized the nut size is 1- 1/2" and not the bolt size. I measured the nut in order to buy the socket - bought a 38mm socket which fits fine. The 1 1/2" nut / 1"bolt size to be torqued to 350 lbs -- and the 1/2" nut 5/16 bolt to 80 lbs right?
~Mark Twain
  #4
Old 10-05-2012
Sabreman's Avatar
Sabreman will become famous soon enough
One of the routine maintenance chores that I do in spring is to tighten keel bolts. I use a 3/4" socket wrench with a 1 1/2" socket and a pipe extender. Then I torque as much as I can. It's a keel. They're big honkin' bolts. As much torque as I can apply is what I want.
With that said, Sabre recommends 90 ft lbs torque.
Sabre 38 "Victoria"
  #5
Old 10-05-2012
anerussis's Avatar
According to the chart 1 1/2" socket is for a 1" bolt - torque to 350 ft lbs - if you tighten past that would there not be a danger of pulling the bolts from the keel or crushing the fiberglass?
~Mark Twain
  #6
Old 10-05-2012
HANUMAN
I can only tell you that I rented a large (monster) torque wrench and sockets from a tool rental joint and followed the chart for 1" bolt w/ 1.5" nut. There where no disasters that followed. If memory serves me...
  #7
Old 10-05-2012
Sabreman's Avatar
Sabre recommends 90 ft lbs for a 6,800# keel. I'm pretty sure that it's a 1 1/2" nut on the bolt, but either way, I tighten as much as I can by hand while the boat is blocked. Close enough. On both my Sabres, I was able to get about 1/8 a turn on some of the bolts the first time that I did it. Thereafter, they've never budged.
If the bolt breaks from hand tightening using a standard socket wrench, then the bolt was going to let go anyway. The keel area is one of the most heavily reinforced areas on all boats. If the fiberglass crushed on a hand tighten, then the keel bed was degraded anyway and it's a blessing that you found out sooner rather than later.
rugosa likes this.
Sabre 38 "Victoria"
  #8
Old 10-05-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
"Give me a lever and a place to stand and I will move the world".
There is a reason torque wrenches were invented - you can exert a HUGE amount of force when you put a pipe extension on a wrench, enough to shear the threads or snap the stud. Stainless steel is also easily galled when too much torque is applied. I can quite easily apply over 100 Ft. Lbs with one hand and a 1/2" drive torque wrench.
Use a torque wrench and tighten the nuts to the torque specified for that size stud. Even a cheap torque wrench is going to be a LOT more accurate than "a piece of pipe and as hard as I can".
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #9
Old 10-06-2012
Sabreman's Avatar
SloopJon- you are correct and I don't do that any longer, just tightening by hand with a regular socket wrench. I should have been more clear in my explanation. Thanks for pointing that out. I should buy a torque wrench, and this may be my impetus.
SloopJonB likes this.
Sabre 38 "Victoria"
  #10
Old 10-06-2012
jgeissinger is on a distinguished road
I am glad SloopJonB made his response. Re-torqueing keel bolts (actually you are torqueing the nuts, not bolts) is a subject that comes up periodically, and almost always with bad advice. He is absolutely correct in that it is not that hard to break perfectly good bolts by over tightening. It should also be noted that torque values are given for clean and lubricated fasteners, which keel bolts and nuts usually are not. Just my two cents.
Sabreman and pvanv1 like this.
You may post attachments
You may edit your posts
Keel Bolt Torque SloopJonB Gear & Maintenance 9 09-06-2011 12:48 PM
Yanmar 2GM20 F Exhaust Riser bolt Torque specs ronsunni Diesel Engine Forum 0 10-08-2009 01:59 PM
MacGregor/Venture Keel Pivot Bolt Torque? CHOCKfullOnuts222 Gear & Maintenance 0 03-31-2009 10:22 PM
Keel bolt torque specs gknott Gear & Maintenance 2 01-19-2009 08:05 AM
Keel Bolt Torque GordMay Gear & Maintenance 2 05-07-2003 09:34 AM
SEO by vBSEO 3.6.1
