Old 10-11-2012
SchockT's Avatar
SchockT is on a distinguished road
Re: Blown main sheet traveler car- need advice ASAP
Yes it happens, but the likely cause was age and weathering. Of course severe impacts don't help either!
If the end caps aren't expensive, just order spares, or at least keep an eye on the new ones and replace them if they look suspect.
1979 Santana 30 Tall Rig
Hull#101
  #12
Old 10-11-2012
mikehoyt's Avatar
mikehoyt is on a distinguished road
There are now alloy end caps to replace the plastic ones. Part # HC2276. In the attached link look about halfway down the page for the paragraph that begins "If you've ever busted the plastic ends on your pre-2004 traveler car, you know what walking on marbles is like." APS - Harken Micro and Small Boat Traveler Components
The other thing that was pointed out is that these are old cars. Mine was built in 1987 and has worked for 25 full seasons before this failure. I am not worried about failure again in my lifetime!
Note - in the link above the forum seems to have put my link under the word APS and Sailnet Store link under the word Harken. Click on the APS word.
Mike
You may post attachments
You may edit your posts
Cabin Top Traveler and Main Sheet SpcAlan1 General Discussion (sailing related) 43 03-17-2011 03:56 PM
EASYCAR main sheet traveler - The quest pedcab Gear & Maintenance 0 05-24-2010 03:26 AM
O"day 28 main sheet FourSeasMilford O'Day 2 09-11-2009 09:13 PM
How loose is your main sheet while raising the main? legarots General Discussion (sailing related) 33 06-24-2009 04:26 AM
recutting my blown out main jollymonjeff Seamanship 6 12-27-2001 09:38 AM
SEO by vBSEO 3.6.1
