Battery water level - SailNet Community
 3Likes
post #1 of 13 Old 10-07-2012 Thread Starter
Question Battery water level
Hello fellow sailors
Can anyone tell me or educate me on this issue that baffles the heck outa me?
Besides my separate starter batteries I have two sets of house battery. One set consists of two 4D connected in parallel. Another set contains four 6V batteries in which 2 pairs are in a series which In turn are in a parallel connection. My question is. Why is it then when I go to top off the water the 4D never require water but the 6 V always do even though the 4D are my primary bats? I am using the 4D and they are always full and the 6V are back ups yet they are always low every two months? Mysterious
Edwin
Lahlia
Cal Cruising 46
Marina del Rey CA
edwmama is offline
post #2 of 13 Old 10-07-2012
Re: Battery water level
Ed
asuming the batteries are still good then the problem is over charging, the charge voltage is set to hi for the batteries or yoiur 3 stage charger wont idle down to a float charge. It's more likley that the batteries are goiing bad and the battery voltage is low as a result. this would cause the charger to think they are low and continually try to charge at bulk charge voltage, which would boil the water out
Brewgyver likes this.
mitchbrown is offline
post #3 of 13 Old 10-07-2012
As mitchbrown says. My guess is that both sets of your house batteries are charged together. Being of different make and likely also different age, they might need slightly different charging parameters.
Petr & Jana
s/y Janna, HR 31 Monsun
klubko is offline
post #4 of 13 Old 10-14-2012 Thread Starter
Angry Re: Battery water level
Originally Posted by mitchbrown View Post
Ed
I noticed that my gauge reads 13.4 at float charge
Shouldn't it be like 12.6?
Is that then an indication of over charging?
I have a xantrex MS 3000 with a combiner for 3 battery banks
What should I do?
edwmama is offline
post #5 of 13 Old 10-15-2012
I just googled it for you, and 13.4v is the ideal float voltage for lead acid batteries.
MarkSF is offline
post #6 of 13 Old 10-15-2012
mitiempo's Avatar
What should I do?
For flooded batteries the MS 3000 has a bulk/absorption voltage of 14.4 and a float voltage of 13.5.
12.6 or higher is the voltage of a fully charged battery when resting without a float voltage present.
Brian
mitiempo is offline
post #7 of 13 Old 10-15-2012 Thread Starter
Thx mark sf and the gang
I guess maybe next time I will just have
Two sets of 4 D bats in both banks
Edwin
Cal Cruising 46
Marina del Rey CA
edwmama is offline
post #8 of 13 Old 10-15-2012
I think what is happening is that the two banks are charged together at the same rate. Therefore, the bank that was not discharged, by being used, will get warmer and use electrolyte at a higher rate - this is inevitable.
I have a simple two bank system with 1/2/both/off switch. I always alternate which bank is used for a daysail, according to the date. Even days - bank 2, odd days bank 1. This is partly to even out the use and the electrolyte consumption.
It's hard to come up with too much of a suggestion because you haven't explained your charging arrangement, which is obviously somewhat fundamental to understanding the problem.
MarkSF is offline
post #9 of 13 Old 10-15-2012
chef2sail's Avatar
Simpler next time to give yourself one large house bank and a separate start bank. You won't have to do all that switching , marking and remembering.
mitiempo likes this.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #10 of 13 Old 10-15-2012
mitiempo's Avatar
It is more efficient and your batteries will, due to shallower cycling, last longer.
Brian
mitiempo is offline
Water Miser Battery Caps mikeedmo Gear & Maintenance 1 08-08-2013 04:02 PM
Oil level in Yanmar 2GM L124C Gear & Maintenance 22 04-20-2009 09:43 AM
Water Miser Battery Caps mikeedmo Gear & Maintenance 2 09-21-2006 05:56 AM
Battery Charge Level danapsy Gear & Maintenance 5 03-16-2006 10:48 AM
Sea Level Visibility Dan Dickison Cruising Articles 0 08-02-2002 08:00 PM
