batteries - Page 2 - SailNet Community
post #11 of 16 Old 03-15-2004 Thread Starter
tm3
batteries
Am aware of charging issues.
All charging equip. is up to date and working properly.
Just trying to get info. the various 6v golf cart batteries out there for my boat.
Thanks to all who responded to date.
Don''t want to buy something not up to par and have problems somewhere where you don''t
want them to occure.
tm3
tm3 is offline
post #12 of 16 Old 03-17-2004
batteries
If you are worried about quality buy TROJAN or DEKo(spelling) batteries. Normal life expentancy under normal use is three years. After that you are living on borrowed time. I got this info from a golf cart manufacturers rep. An amp hour meter is absolutely neccessay for a cruising boat, you need to make sure that the batteries never discharge below 50% or their rated capacity.
JoseASantin is offline
post #13 of 16 Old 03-17-2004 Thread Starter
tm3
batteries
Based on info. learned to date I''m seriously thinking of going with Trojan. And spelling is Deka.
Prices vary between the two of about $10.00 with Deka being higher. Weight, amp hours per 20 hours usage and warranty are basically the same.
Big issue now is battery compartment size in the salon below the sole.
Thanks
tm3
tm3 is offline
post #14 of 16 Old 03-18-2004
batteries
Four batteries are sufficient for normal cruising use. As for location, are you aware that seawater and battery acid produce chlorine gas when combined? That is the only major drawback to wet cell batteries on boats. If you are planning to place batteries below the sole I would seriously consider making the compartment watertight and providing it with a snorkel into a high spot in the engine compartment. By products of charging are hydrogen and other gases that you do not want to breathe. Antoher item you want to invest in is a specific gravity tester, this will allow you to identify weak cells. Not all batteries are good even if new. Once you leave the states warranty replacements will become a headache.
There is a lot of battery information in the Ample Power website, some of it is self serving but most is very informative. Don''t forget about proper size fuses there should be one coming out of the alternator and another between the battery bank and the electrical panel. The only unfused connection allowed is between the batteries and the starter motor.
Best wishes
post #15 of 16 Old 03-18-2004 Thread Starter
tm3
batteries
Sealed battery boxes under the salon sole are above the bottom of the boat by several inches. Have not had any problems over the last two seasons with water coming in in that area.
Have a gravity tester.
Have visited several sites involving battery info. including Ample Power.
When I purchased the boat the prior owner had six 6v batteries hooked up for the house bank. Thus I''ve kept it that way without problems. But he never replaced all at one time. From what I could determine he purchased two new every three years. The marina electrican cited several of the older batteries were low and drawing from the newer ones.
I''m going to replace all six and go from there.
Thanks for the info.
tm3
tm3 is offline
post #16 of 16 Old 03-22-2004
batteries
I hear that the battery you are talking about can be bought at Sear''s and is the same battery made by exide.Maybe sear''s will have some info on them.I am not sure about all that weight.
sailnaway is offline
Sulphated batteries drynoc Gear & Maintenance 6 05-11-2005 06:29 PM
Batteries tm3 Gear & Maintenance 20 12-08-2003 03:10 PM
Nickel Zinc Batteries Hansdg53 Gear & Maintenance 0 04-02-2003 09:49 AM
battery nightmares pmills42255 Gear & Maintenance 9 03-16-2003 07:17 AM
Charging Batteries navtron Gear & Maintenance 1 01-12-2001 05:57 AM
