Stainless lock washer or locktite - SailNet Community
post #1 of 7 Old 10-08-2012 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Hello,
This last weekend I noticed that the bolts holding down my blocks for halyards and reefing lines at the base of the mast were all loose, one was completely out. My question is:
Clearly I need to check them more often.
What would be better, stainless lock washers (stainless is a bit soft) or locktight (or competitor)?
Regards,
Craig Kelly
s/v Kairos
kellysails is offline
post #2 of 7 Old 10-08-2012
Brewgyver's Avatar
Re: Stainless lock washer or locktite
Is this a nut and bolt combination, bolts through deck with nuts, etc, underneath? I'm assuming you don't have bolts (machine screws) threaded into the mast itself. If the materials are alike (e.g. all 304 SS), then Loctite blue should hold everything snug. You also have to make sure that the blocks themselves aren't torquing against the fastener, slowly unscrewing the connection.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #3 of 7 Old 10-08-2012
I use lock washers exclusively but locktite is good and has the benefit of not rolling off the deck or under something when you remove the nut.
VetMike is offline
post #4 of 7 Old 10-08-2012 Thread Starter
Puget Sound Pounder
kellysails's Avatar
The bolt threads into a receiver glassed into the deck.
So it sounds like Locktite Blue is the way to go here. Thanks!
Ordered from Amazon, will receive Wednesday.
Regards,
Craig
s/v Kairos
post #5 of 7 Old 10-10-2012
Bear in mind, LocTite works best on clean threads. So you did place an order for the cleaner/rpimer too, right? (G)
Alcohol, toothbrush or wire brush. Or at least a paper towel and alcohol first.
hellosailor is offline
post #6 of 7 Old 10-11-2012
overbored's Avatar
the screws through the cabin top should be sealed so they don't leak and the sealer makes a good thread locker. I use 3M 4000 marine sealer and elastic lock nuts.
"GOLD RUSH" PRINDLE 16
overbored is offline
post #7 of 7 Old 10-11-2012 Thread Starter
Puget Sound Pounder
kellysails's Avatar
Thanks, on it! -craig
Winterization- Use of Winshield washer fluid BrightAyes Gear & Maintenance 4 10-14-2009 02:15 PM
washer for keel bolts rperret Gear & Maintenance 7 07-05-2008 10:11 PM
Kariba Washer daddyhobbit Gear & Maintenance 0 01-31-2008 11:37 AM
Washer/Dryer onboard reid5009 Living Aboard 6 06-17-2007 10:09 PM
washer dryer combo KenD Gear & Maintenance 2 07-02-2002 03:59 AM
