What kind of hardware? - SailNet Community
post #1 of 7 Old 10-08-2012 Thread Starter
I want to put a safety line on the underside of the boom to serve as a handhold and sliding anchor for my harness when I have go to the mast. I am looking for suggestions/feedback for what kind of hardware to use at the aft end of the boom. I am considering a U-Bolt with backing plate through the bottom of the boom. I have a Cal-27 with liftable cabin top, so I can not secure the safety line to that. Any experience?
mikevehlow is offline
post #2 of 7 Old 10-08-2012
Living the dream
ReefMagnet's Avatar
Re: What kind of hardware?
Hmmm, not sure that is a great idea - think unintentional gybe. The usual approach are webbing jacklines. My boat had a previous owner install a rollcage out of 1" stainless on top of the cabin that makes a perfect anchor point. I guess if you were to persist with the idea something using boom bales would work.
ReefMagnet is offline
post #3 of 7 Old 10-08-2012
Why not follow convention and fasten two (2) jack lines, port and starboard from bow to stern. Heavy flat belting (think seat belt) laying flat on the deck. Wear a harness and tether. The tether has a 3' and 5' lengths for transiting your mast.
Dick
Flybyknight is offline
post #4 of 7 Old 10-09-2012
chucklesR's Avatar
Seriously not a good idea to fasten a safety line to a moving object.
chucklesR is offline
post #5 of 7 Old 10-09-2012
Irrationally Exuberant
I'm picturing a boat out there with a guy dangling from the boom whose mainsheet tackle has busted. Then again, I've always thought the conventional way with jacklines on the side decks is a very false security--if you go over, sure you're still attached to the boat, but you're in no better shape than the guy dangling from the boom--maybe worse.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #6 of 7 Old 10-09-2012
SchockT's Avatar
Yeah I agree that it is a very bad idea! What happens if you go overboard while tethered to the boom? Whoever has to help you will have no control over the mainsail! If they want to dump the main to slow the boat it will drop you deeper into the drink, and your body weight will keep the sail sheeted on hard!
Don't reinvent the wheel, just use jacklines!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #7 of 7 Old 10-09-2012
rugosa's Avatar
You would be BAIT
rugosa is offline
Tags
equipment
What kind of boat is this? L124C Sailboat Design and Construction 5 10-09-2012 04:59 PM
What kind of boat is this? ShockValue General Discussion (sailing related) 23 01-17-2011 12:35 PM
FRP (Not the kind you think...) PorFin Gear & Maintenance 3 11-26-2008 09:32 PM
What Kind ? Freesail99 Gear & Maintenance 2 05-10-2007 04:50 PM
