Stuffing Box Stopped Dripping - SailNet Community
 2Likes
post #1 of 12 Old 10-09-2012 Thread Starter
casey1999's Avatar
For the past two years my stuffing box dripped about 2 drops a minute at the dock and 5 drops per minute while running under power.
Recently the box stopped dripping at the dock and drips almost nothing when running. In a year or two I had planned to put the boat on the hard and install new stuffing box and hose.
The existing box is hard to get to (V-drive) and is corroded so I did not want to tighten when it was leaking a lot. No it is basically not dripping at all, and although I know I need to adjust it to get it dripping, a little afraid I might end up in a situation where I need to to an emergency haul out. A haul out here with storage is in the $1,500 range so it is somthing I want to plan for so I can do other work like painting hull, bottom, and pulling stick to re-rig.
Any ideas why a leaky stuffing box would basically stop leaking?
casey1999 is offline
post #2 of 12 Old 10-09-2012
THEFRENCHA's Avatar
Re: Stuffing Box Stopped Dripping
Too tight! You can unlock a bit without major risk
THEFRENCHA is offline
post #3 of 12 Old 10-09-2012 Thread Starter
casey1999's Avatar
Normally as the stuffing box packing wears you would need to tighten the packing nut to compensate and slow the drip. I have never tightened the nut and did have an excessive drip rate.
What would cause the drip rate to completely stop, when the nut was never tightened?
post #4 of 12 Old 10-09-2012
Gene T's Avatar
My old stuffing box on my N30 would stop dripping if I didn't use it for a while. When I installed new packing used teflon imregnated packing with use plenty of teflon grease. I set it to not leak when not running. I would check the tempeature while running to make sure it did not get warm. Have you checked temp while running?
Hard to get at but there is nothing complicated about them. And it is very doable while boat is in the water. There isn't enough of a water leak when you take it apart that a bilge pump can't easilly keep up with.
Gene
rikhall likes this.
Currently in Long Beach, CA
Gene T is offline
post #5 of 12 Old 10-09-2012
snake charmer, cat herder
zeehag's Avatar
salt build up and corrosion make the cessation of dripping. even mine will stop almost entirely when i have spent too much time on a dock...
formosa 41, cruising tropics
zeehag is offline
post #6 of 12 Old 10-09-2012
THEFRENCHA's Avatar
Had same situation this summer. Did not really look for an explanation
Probably salt
Just slightly untighted and voila
Dripping again
post #7 of 12 Old 10-09-2012 Thread Starter
casey1999's Avatar
Gene
I felt the box and prop shaft after running for a while- nothing was hot. I will PB blast and clean up and try to loosen the box and get some drip.
post #8 of 12 Old 10-09-2012
old guy :)
rikhall's Avatar
Mine is easy to get to, even while the boat is running. Mine drips very little and like others have said, some times really leaks very little or seems to stop.
In that condition I have put my hand (carefully - but it is very safe and handy) on the stuffing box and it is slightly warm, not a problem at all.
Rik
Irwin Citation 34
Mystery
rikhall is offline
post #9 of 12 Old 10-10-2012
I used an electronic laser temp sensor to check the stuffing box while under way after tightening. I do not know what the temp should be but mine was running about 95 deg in 80 deg water with a drip about every 60 to 70 seconds. No drip while not in operation. I am in fresh water.
rikhall likes this.
H and E is offline
post #10 of 12 Old 10-10-2012 Thread Starter
casey1999's Avatar
Thanks for the replys. So as long as the box/shaft is not hot I should be good, even with minimal drip. Will keep an eye on it.
Stuffing box nt dripping at all GaiaOrion Gear & Maintenance 3 08-17-2012 12:39 PM
Dripping Stuffing Box jahjammin Gear & Maintenance 29 04-16-2012 10:18 AM
Dripless Packing seal is Dripping Valmika Gear & Maintenance 7 04-23-2011 10:55 PM
Dripping Wet Cave Lockers tager Living Aboard 3 05-13-2009 07:23 PM
Oil dripping over the side ? t4li3sin Seamanship & Navigation 13 05-01-2009 02:41 PM
