Hawse Pipe - SailNet Community
post #1 of 4 Old 10-09-2012 Thread Starter
Hawse Pipe
What is the best deck mounted hawse pipe? The one I have has the lid held on by a chain and it does not stay in place, letting spray into the boat. Are the hinged ones any good? I have seen pictures of people using a dorade vent as a hawse pipe. Is that a good idea?
Thanks for your help.
ccriders is offline
post #2 of 4 Old 10-09-2012
Re: Hawse Pipe
When you say you get spray in the boat, is the anchor locker exposed to the interior of the boat? If so, I would address that by blocking it off. Hawse pipe's can not be weather proof and chain lockers are usually designed to drain. In fact, I prefer water get down there to help clear dirt from the chain.
Jeanneau 54DS
Minnewaska is offline
post #3 of 4 Old 10-09-2012
Re: Hawse Pipe
I have a hinged one and sometimes it works open with the chain blocking it up slightly. I've thought about replacing it with one like you have! (But there are many more things ahead on The List.)
If you have enough weight from the chain hanging on the cap, it should keep the hawse pipe closed. I've thought about brazing a hook onto mine for just this purpose.
Plumbean is offline
post #4 of 4 Old 10-09-2012 Thread Starter
Re: Hawse Pipe
Minnewaska,
The anchor locker has a large opening in the V berth, but basically it drains into the bilge. However the forward bilge is not open to main bilge (nor is the aft bilge). Some P28 owners have installed nice cabinet doors to close off the anchor locker from the V berth. I have always tried to clean the chain before lowering it so that mud does not accumulate as it did for the PO.
Plumbean,
That is a good idea to put a chain hook on the cover and let the weight of the chain do the work.
ccriders is offline
Sampson Cay to Little Pipe Cay 5/30-5/31/10 skipgundlach Cruising & Liveaboard Forum 0 06-04-2010 10:29 AM
Stainless Hot Pipe? downeast450 Gear & Maintenance 0 02-19-2010 01:55 PM
Who knows Pipe to Hose?? Skipper Joe Gear & Maintenance 5 06-15-2009 01:14 AM
best pipe dope? scosch Gear & Maintenance 10 02-15-2009 09:46 PM
Pipe bunks Wolfsong Gear & Maintenance 16 05-13-2008 09:59 AM
