How to repair a pulled forestay tang on a classic yacht... - SailNet Community
 1Likes
  • 1 Post By CharlieCobra
post #1 of 8 Old 10-10-2012 Thread Starter
On the hard
CharlieCobra's Avatar
As some of you folks recall, the Lady suffered a forestay tang failure while under sail to windward. Luckily she didn't lose the rig and was able to limp back to us under power for repairs. Here's a look at the damage:
Once we got her hauled and the rig down, the hard part came. How to repair her without ripping the boat apart? Well, we came up with a plan....
I cut the damaged section of the Stem out in order to insert a "Dutchman" if you will, into the existing Stem:
While taking her apart, we found a signature from her construction.
Once I had her cleaned up, including cutting out a section of the foredeck and the forepeak cap: We then made pieces to fit back to where they were, which was not an easy task, starting with the Stem insert:
Then we received the modified tang and discovered a couple of things. First, it was bent during the welding of the additional parts and the design was changed enough that it no longer fit.
Ok, now I get to play Blacksmith... I also had to cut in a recess to fit the new tang top, which created another issue. It left 1/2" gaps to each side of the tang because the back was wider than the front and you couldn't set it in vertically this led to making mahogany fillets to fill the gaps.
The deck was a two layer laminate of a 1/2" top layer over a 1/4" base, with the seams staggered four inches and the whole thing laid up in glass and epoxy.
This time she was thru bolted properly:
Anyway, here's the finished product some 50 Hrs. later.
Hopefully, the owners get to sail her a while before bringing her back to us...
Gene T likes this.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #2 of 8 Old 10-10-2012
Re: How to repair a pulled forestay tang on a classic yacht...
Wow. Nice work.
I was wondering how you guys were going to tackle that one.
smackdaddy is offline
post #3 of 8 Old 10-10-2012 Thread Starter
On the hard
It was a challenge but not impossible...
Bellingham, WA.
post #4 of 8 Old 10-10-2012
Gene T's Avatar
Nicely done as usual. You continue to impress me.
Gene
Currently in Long Beach, CA
Gene T is offline
post #5 of 8 Old 10-10-2012
casey1999's Avatar
Was original tang bronze and you welded the break?
Nice work....
casey1999 is offline
post #6 of 8 Old 10-10-2012
Send a message via Yahoo to dacap06
Wow, Charlie. I must say that is an awesome job! What craftsmanship!
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #7 of 8 Old 10-10-2012 Thread Starter
On the hard
Nice work....
The original tang didn't break, it was just too short. The extension and the breastwork sides were welded on and yes, it is silicon bronze. No, we didn't weld it.
Bellingham, WA.
post #8 of 8 Old 10-11-2012
Irrationally Exuberant
Charlie, your work just makes my day! Really!
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
Tags
baggett and sons , repair , wooden boat repair
Classic Yacht Race ncarter Racing 6 02-28-2011 08:39 AM
classic or modern yacht? stayks Learning to Sail 5 02-08-2011 05:59 PM
St. Maarten-st. Martin Classic Yacht Regatta Foundation Launching A Classic Yacht Sailing Fundraising Program To (Nautica) NewsReader News Feeds 0 07-05-2006 10:15 AM
Classic Yacht 26' ozarkmom43 Boat Review and Purchase Forum 0 05-16-2006 11:47 PM
Classic Yacht Builders ldcarpet General Discussion (sailing related) 1 10-06-2001 01:10 PM
