slightly soft floor remedies - SailNet Community
 1Likes
post #1 of 25 Old 10-11-2012 Thread Starter
floridajaxsailor's Avatar
I am sure there has been lots of chat regarding soft floors in 1970s era sailboats, in the 20-35 foot range
I have an old C & C in super shape
the central wood panel that covers the bilge has a slight soft floor
around it, not bowing, just a bit soft
any magic cures?
one idea was to inject some construction filler/adhesive...
or a big no no?
years ago we used this foaming yellow sealant for a rough opening
in new construction, I remember the stuff has to be dealt with care as it
expands, the name escapes me & it came in a can with a tube
anyhow, any thoughts are appreciated
floridajaxsailor is offline
post #2 of 25 Old 10-11-2012 Thread Starter
post #3 of 25 Old 10-11-2012
Re: slightly soft floor remedies
There are a lot of ways to patch it, but none of them are worth the effort. What you have is a section of plywood that has either rotted, or the glue has dissolved.
The right fix is just to replace it. Take the old piece and use it as a template for the new one. You are looking at maybe a few hundred dollars for the plywood, and an afternoon cutting it to shape, and then a few days varnishing. Compare this to any cheap fix, that might last a year or two, and then you are right back where you are now.
Greg
Stumble is offline
post #4 of 25 Old 10-11-2012
chef2sail's Avatar
My winter project is to replace the sole on our C&C 35MKIII. It has about 7 different sections to it. The floor is screwed down on the horizontal stringers and longitudinal ribs.It can be taken up easily. What you find underneath I am sure will take some cleaning as my boat is 30 years old this year. In addition it will give me a chance to clean the limber holes,replace bilge pump hoses, and examine the structural integrity of the stringers also.
Teak and holy 3/4 inch is sold in 5X8 ft sheets in this area for about $ 400 a sheet. I intend on taking up the floor sections and taking them to someone with the appropriate commercial saw to fabricate them using the the sections as templates. We will put some epoxy layers on the bottoms of the boards before they go down.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #5 of 25 Old 10-11-2012
jsaronson's Avatar
Exotc Lumber sells 4 x8 shheets for 275.
jsaronson is offline
post #6 of 25 Old 10-11-2012
Hard telling what's living under there. Once you pull the floor the stringer renovation will be on
You might consider putting down some 1/2" marine plywood coated with resin & using a 1/4" teak holly sole, could be cheaper.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
post #7 of 25 Old 10-11-2012
Gary M's Avatar
Wish I had seen this last week, drove back from the Annapolis Boat Show in my van. could have brought a sheet back. Anyone know of a supplier closer to say Detroit?
Gary
Gary M is offline
post #8 of 25 Old 10-11-2012
chef2sail's Avatar
Joel.
I have been to Exotic Limber looking,,,neat place. I took by Bildge insert there it matched up with the T&H that was 400 maybe I should go back an remeasure $275 sounds better
Dave
Parkville, Maryland
Our blog-
post #9 of 25 Old 10-11-2012
jsaronson's Avatar
Unless 5 x 8 lets you get by with one sheet! Thinking about stripping my cabin sole this winter, but I'll probably find something else to do with my time.
post #10 of 25 Old 10-11-2012 Thread Starter
Dave,
what a wonderful reply w data
how I wish I could take this old lady out to complete the project correctly
am jealous
the New England Carpenter I worked with years ago always had that approach to start with the foundation clean & dry
how were you going to get below the fiberglass skin that covers the flooring? cut it all out? wow what a project...
the stringers are hopefully overall intact, is there any thoughts on the foam, I am supposing it is a wasted remedy as my floor is not overall soft, Amen
take care
Effective remedies for the no-see-ems sailhog General Discussion (sailing related) 32 02-06-2015 04:44 PM
Seasickness remedies Irwin32 Gear & Maintenance 26 12-10-2010 10:25 PM
Need material to raise floor of bilge slightly saltypat Gear & Maintenance 5 09-20-2007 07:30 PM
More Natural Remedies William Mahaffy Seamanship Articles 0 12-18-1998 07:00 PM
