Foul Weather Gear - Page 2 - SailNet Community
 9Likes
post #11 of 45 Old 10-12-2012
Re: Foul Weather Gear
Strongly consider "coastal" or "in-shore" foul weather gear, which is cheaper and more versatile than "off-shore" gear. Combined with a polypro base layer and a watch cap and a pile layer you should be comfortable over a wide range of conditions. Avoid foul weather gear that has so much velcro that you'll find your arms sticking to your torso or open "hand warmer" pockets that snag your tiller or winch handle. Your jacket should have a zippered, inside, chest pocket; flaps over the zippers, and a hood that fits you.
Bibs aren't as critical but wide suspender straps with delrin clips that you can open with gloved hands are nice.
Hudsonian is offline
post #12 of 45 Old 10-12-2012
Gene T's Avatar
Originally Posted by chucklesR View Post
The best foul weather gear is a full enclosure, and lines led aft. A small propane heater (1500 BTU on a 2 pound bulb) and a waterproof wind breaker is all it takes.
Strongly disagree, The best option it to sail South till you don't need shoes.
Gene
Glory Be likes this.
Currently in Long Beach, CA
Gene T is offline
post #13 of 45 Old 10-12-2012
chef2sail's Avatar
Gil Spinakker
FWG is what my wife and I have and are on the Chessie also. They are comfortable. Can be used in all seasons, even in the summer. The hood, head jacket all fit well and do not rub. Accomadations for easily going to the bathroom on ladies model ( importatnt in small heads so you dont have to remove the whole bib). Great waterproofed materieal with articulated elbows and knees. Very breathable.
When you buy dont get tight so you can layer underneath
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #14 of 45 Old 10-12-2012
chucklesR's Avatar
Gene
I grew up in West Virginia - what are shoes?
chucklesR is offline
post #15 of 45 Old 10-12-2012
Gene T's Avatar
Horses wear them
Gene
Gene T is offline
post #16 of 45 Old 10-12-2012
johnnyquest37's Avatar
There are two key things to consider and several secondary things. High tech and low tech solutions are available.
To stay happy, you need to remain warm and dry. Use layered clothing to obtain warmth. The colder it is, the more layers you'll need. Just my preference - cotton or silk layer on the skin, followed with cotton or cotton/synthetic blend shirt/pants, followed by wool or synthethtic light fleece or sweater, followed by coat liner, with a water-resistant top layer (coat). If really cold, you can double up some or all layers. Same layered approach to feet torso and legs. To stay as dry as possible, you'll need to both repel water (rain/spray) and wick your perspiration away from your skin. Having that wool or hi-tech synthetic layer will help retain heat even when that layer gets wet. On the outer coat, take care that the openings for your hands and head don't allow too much water to get in and that the zippers, pocketss, etc. don't let the water sneak in. The top layer needs to be baggy enough to cover all these layers. Keep all the layers loose except perhaps the layer on your skin.
Warm and dry are essential. Other things to consider:
-- Does the outer coat's hood keep water out and allow you good visability? Some hoods are useless or block your field of view too much.
-- Can you access pockets, adjusting straps, zippers, etc. without compromising the whole set up? Outer gear with exterior as well as interior pockets work well.
-- Can you get out of the gear to use the head, change a t-shirt, etc, fairly quickly?
-- Is the gear dual use? I don't want hot weather gear and cold weather gear. Rather have rain gear that works in warm weather that I can layer underneath for cold weather service.
We've spent our money on good qualit, lighter outer layer components - top coat, bibs, good boots and we use Goodwill items to make up all the rest of the layers.
Warm and dry
[/B]S/V Wind Orchid
Catalina 350 (hull# 273)
Annapolis, MD
LET'S GET SERIOUS ABOUT REMOVING POLITCAL TAG LINES -- NOW!
johnnyquest37 is offline
post #17 of 45 Old 10-12-2012
I bought these new for less than $90.00:
http://www.overstock.com/Sports-Toys...4/product.html
They rock.
smackdaddy is offline
post #18 of 45 Old 10-12-2012
DrB
Second Reply
As I and others have said - WM stuff is perfectly adequate for your needs if you're mainly coastal stuff. Even their Off-Shore/Ocean Stuff is decent for the price. I have a set of their Third Reef Jacket and bib and mostly wear that when the need arises.
While REI/Cabela's, EMS make nice waterproof stuff, think twice about using it as extended/primary FWB. Typically theses garmets are made with lighter weight cloths, which can more easily catch and rip on cleats, shackles, cotter pins, etc., than "boat" stuff. Also a foulie good jacket has cuff seals that minimizes water running down your arm from your hand. Most camping/hiking waterproof jackets don't. Camping/hiking jackets are also usually cut shorter in length torso, than boat foulies. So when you have to bend over, if the camping jacket isn't long enough, you could get water on/down your back if not wearing bibs or bibs high enough. Not all camping waterproof jackets are short, but some are. Not saying that camping/hiking waterproof stuff isn't okay for use on the boat, but it will be more prone to ripping/damage than the typically more durable boat stuff. That being said, I use it all the time for light duty day sails in spitting rain, but heavier rain, I bring out the boat stuff.
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
post #19 of 45 Old 10-12-2012
jackdale's Avatar
Agree with layering
Polypropylene first layer
Fleece second layer - if needed. I also wear quick drying hiking pants as a second layer when I do not need the warmth.
Good quality foulies - HH offshore bib pants and Gill Atlantic jacket. I invested more in pants as a like a dry bum. I wear the pants more than I wear the jacket.
If it is warm I wear sandals (with enclosed toes) instead of shoes or boots. I treated myself to DuBarry Ultimas this year for warmth. I hate wet socks which is why I am gave up on shoes for wet conditions; I still wear shoes for coastal sailing.
For gloves: warm conditions sailing gloves. For cold and wet I wear cheap rubber work gloves for which I have two sets of HH inserts, one to wear while one dries out.
Two of my crew back from Maui had Musto's which they really liked.
Caring for your foulies is important. If you have to re-waterproof there are some good products out there. I use Grainger's for washing and spray.
jackdale is offline
post #20 of 45 Old 10-12-2012
Yes, I second the "overstocked.comfoulweather gear" for under
$90. ...great value.
I bought a set last year as a 3rd set, to keep on board for crew,
and was impressed. We sail in winter here in N.Y. with my Gil coastal and would not hesitate to use this set.
There is a whole thread on this set from last year.
HUGOSALT is offline
Foul Weather Gear AZBlueDevil83 General Discussion (sailing related) 10 04-14-2009 02:19 AM
Foul weather gear voice3 Gear & Maintenance 14 02-05-2009 07:29 PM
Foul Weather Gear conery Gear & Maintenance 10 03-11-2008 02:02 AM
Foul weather gear locrian13 herSailNet 30 08-01-2007 06:19 PM
Foul Weather Gear crl21 Gear & Maintenance 2 08-09-2006 12:24 PM
