seacocks for cockpit drains? - SailNet Community
post #1 of 12 Old 10-12-2012 Thread Starter
I recently purchased a Spirit 28 (my first real boat).
All through hull penetrations have seacocks, with the exception of those in the aft end: engine exhaust, bilge pumps, and cockpit drains. the exhaust and bilge pumps penetrations are just above the waterline, but the cockpit drains are a little below. For all these systems, I worry that a hose failure underway would leave me without a way to secure the flow (although I would obviously leave them open when away from the boat, limiting their potential value).
Do cockpit drains normally have seacocks? How about bilge pumps and engine exhaust?
Russ
Rusty123 is offline
post #2 of 12 Old 10-12-2012
Re: seacocks for cockpit drains?
No, bilge pumps, exhaust or cockpit drains never come with seacocks.
Catalina 34
chuck53 is offline
post #3 of 12 Old 10-12-2012
To the cockpit drains.....I wouldn't say never...my Sabre has seacocks at the cockpit drains. They remain open. They are not easily accessible, and I need to crawl down there and maintain them after I lose another 5 pounds.. :-)
tempest is offline
post #4 of 12 Old 10-12-2012
asdf38's Avatar
Are the drain outlets fully below the waterline? I wouldn't expect them to be although on smaller boats the cockpit floor can be pretty close to the waterline (I had 8 people onboard and the cockpit flooded with a pool of water once).
On my boat they are at the waterline not below it. In addition the hose fitting is a few inches long and comes out at an angle effectively raising the level required to actually get into the boat. So in theory, in flat water, I suspect I would stay afloat with no hoses. Not that this is likely, waves would sink it quickly I'm sure.
But I second the plug. It's probably worth the $10
Plastimo Wood Plugs Set Of 6
asdf38 is offline
post #5 of 12 Old 10-12-2012
Dirt Free
boatpoker's Avatar
Transport Canada Small Vessel Construction Standards TP1332E require seacocks on all hull penetrations except the exhaust.
ABYC Seacocks, Thru-Hull and Drain Plugs, Standard H-27 requires all piping, tubing or hose penetrating the hull below the maximum heeled waterline be equipped with a seacock except for exhaust which must be double clamped.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #6 of 12 Old 10-12-2012
Wish I never found SN!
SimonV's Avatar
Not so sure about the cockpit drains, mine has seacocks. I have never closed them for the obvious reasons but its still nice to know they are there and they work.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #7 of 12 Old 10-12-2012
Dirt Free
boatpoker's Avatar
Hope you excercise them once in a while or they won't work when you need them.
I can do that
- wg
post #8 of 12 Old 10-12-2012
bristol299bob's Avatar
I have seacocks on my cockpit drains. I leave them open but I cycle them as I go through the boat to close all of the others before leaving.
Do make sure that they are double clamped, and the hose is good.
bristol299bob is offline
post #9 of 12 Old 10-12-2012
Dirt Free
boatpoker's Avatar
Here is a good example of how a second clamp can do more damage than good. The second hose is not over the nipple on this cockpit scupper and tightening it is actually pulling the hose off the nipple. In fact this is an old mechanics trick to get off stubborn hoses.
I can do that
- wg
post #10 of 12 Old 10-12-2012
Courtney the Dancer
jrd22's Avatar
All below water line through hulls should have sea cocks, including scuppers.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
Cockpit Drains C-27 Mark1948 Catalina 2 05-02-2008 08:39 AM
Cockpit drains gg30citation Gear & Maintenance 40 02-27-2008 11:51 PM
Cockpit Drains SimonV Gear & Maintenance 6 04-13-2007 10:40 AM
Leaking Seacocks and Sink Drains Tom Wood Buying a Boat Articles 0 09-11-2002 08:00 PM
Leaking Seacocks and Sink Drains Tom Wood Gear and Maintenance Articles 0 09-11-2002 08:00 PM
