Jib furler is hard to furl since putting up new sail...ideas? - Page 3 - SailNet Community
 2Likes
post #21 of 32 Old 10-13-2012
Tartan 27' owner
CalebD's Avatar
Re: Jib furler is hard to furl since putting up new sail...ideas?
Could your upper swivel need lubricating?
Everybody has one:
CalebD is offline
post #22 of 32 Old 10-13-2012 Thread Starter
NewportNewbie's Avatar
Maybe. Won't hurt to drop the sail and lubricate it. I don't think that's the problem though because it was a drastic change when I put the new and slightly shorter sail up but it may have just made that worse.
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #23 of 32 Old 10-13-2012
Send a message via Yahoo to dacap06
Originally Posted by SchockT View Post
It could also have to do with the shorter hoist on the new sail. There is more halyard between the mast exit and the swivel, and it will be at a shallower angle, more parallel to the forestay, and as result it could twist around the forestay.
This is exactly right. Have your favorite sail loft make a penant for you that is the same length as the differences in the sail luffs so the head raises all up the forestay.
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #24 of 32 Old 10-14-2012
Based on the above 23 postings:
a. If its halyard wrap, add a retainer (restrainer).
b. Adjust halyard tension.
c. Check for unrestricted routing of the furling line.
d. Check furling line wrapped around drum correct way. (duh!)
Cheers
chef2sail likes this.
Seaduction is offline
post #25 of 32 Old 10-14-2012
floridajaxsailor's Avatar
and...
Also, unless a jib sheet in a squall, never pull on a stay/halyard with all your body weight as you mention that is a recipe for disaster down the road good luck with your sailing~ sounds like the guys above figured it out
floridajaxsailor is offline
post #26 of 32 Old 10-14-2012
A smaller line effectively reduces the diameter of the furling drum especially when the sail is all the way unfurled. Using a line large enough to fill the drum when the sail is completely furled would making furling easier. Alternately, use a much longer small line, and fill the drum completely that way. Since the effective drum diameter is larger the effort will be much less.
GaryHLucas is offline
post #27 of 32 Old 10-15-2012
My halyard block is welded to the top of the extrusion, and I take the tail away, and tie the halyard to the drum, after the sail has been hoisted. Then I tighten it with a downhaul on the drum. A friend, who worked in a riggers shop, said a lot of people were doing this, and getting away from the halyard swivel althogether.
Brent Swain is offline
post #28 of 32 Old 10-15-2012
overbored's Avatar
this will not work on internal halyards and puts a lot wear on the block swivel which will eventually fail
"GOLD RUSH" PRINDLE 16
overbored is offline
post #29 of 32 Old 10-30-2012
Did OP ever resolve the problem with the hard furling????
post #30 of 32 Old 01-03-2013 Thread Starter
Have not done much. It's not too bad. Gonna raise the sail about 4 inches. That's should solve the problem.
Furler hard to unfurl/furl on genoa Romario Gear & Maintenance 14 06-22-2012 01:11 PM
Old Roller Furler (a.k.a. "To Furl, or Not To Furl...") supergrade Gear & Maintenance 34 12-24-2008 11:36 AM
Putting a boat on the hard? mgalvez Boat Review and Purchase Forum 9 02-14-2008 11:37 PM
Sail modifications for a CDI furler Guesser Gear & Maintenance 2 03-31-2007 11:03 PM
Need my sail covers on my furler sail replaced NickL Gear & Maintenance 1 02-22-2007 10:38 AM
