Heat gun & veneer plywood - SailNet Community
 1Likes
  • 1 Post By Flybyknight
post #1 of 7 Old 10-13-2012 Thread Starter
Has anyone had problems removing varnish on veneer plywood with a heat gun. On solid timber no problem, just keep moving but does this apply to veneer or is the outer layer too delicate?
jamesjle is offline
post #2 of 7 Old 10-13-2012
Tartan 27' owner
CalebD's Avatar
Re: Heat gun & veneer plywood
I'd be concerned as you are of causing the outer layer of wood laminate to buckle away from the lower layers. The glue between the layers might, or might not hold fast.
No way to know without trying.
I'd have similar concerns if using a paint stripper.
If it does pull up or buckle you could remove the buckled sections and cover it with thickened epoxy and sand fair.
Everybody has one:
CalebD is offline
post #3 of 7 Old 10-13-2012
Tried it and the veneer delaminated.
Had better luck heating a paint scraper as I was scraping the varnish.
Dick
CalebD likes this.
Flybyknight is offline
post #4 of 7 Old 10-14-2012 Thread Starter
Thanks for the confirmation, I thought it would be a bit dodgy, in a forepeak, fiixed bulkhead over damagable repainted bilges...... Back to the Bahco
jamesjle is offline
post #5 of 7 Old 10-14-2012
poopdeckpappy's Avatar
Try a little citrus strip and a cabinet scraper
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #6 of 7 Old 10-15-2012 Thread Starter
How does citrus strip feel about one pack polyurethane?
jamesjle is offline
post #7 of 7 Old 10-15-2012
I find that citrus strip is a equal opportunity striper, has worked well on everything I've used it on
1974 Ranger 33
Okoume Plywood veneer petergumbrell Gear & Maintenance 8 04-19-2010 06:56 PM
Teak and Holly Veneer Only? brianontheroad Gear & Maintenance 24 02-19-2010 08:35 PM
bleaching veneer lbdavis Gear & Maintenance 20 04-09-2008 10:11 AM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 01:12 AM
Teak Veneer nesailor Gear & Maintenance 3 01-06-2005 04:33 PM
