Air Head Composting Toilet or Similar Mfg. - Page 11 - SailNet Community
 24Likes
post #101 of 165 Old 05-02-2013
Fresh water refugee
katsailor's Avatar
Re: Air Head Composting Toilet or Similar Mfg.
Thanks to all the posters on this thread, I have learned a lot and am considering a composting toilet once I finish
  1. Painting the engine compartment
  2. Installing new wiring
  3. Removing the non-working head and associated plumbing. (I think someone installed a regular marine head on a laval system, still trying to figure out where all the hoses go)
  4. Install the engine
  5. Replacing the running rigging
  6. Fix that funny crack I just found by the stuffing box
  7. Rebuild the steering system; just when I thought everything that could break was broken the sheave assembly for my wheel steering fell off.
Experience teaches us things we would rather not know.
S/V Shakti '81 Offshore Cat Ketch 33'
katsailor is offline
post #102 of 165 Old 05-02-2013
Originally Posted by Captainmeme View Post
Can someone describe the agitator mechanism for me? Does one rotate the crank 360 degrees or is it a back and forth action?
You crank it 360 degrees . I use a round hoop made of 5/16th stainless rod, with the crank handle at 90 degrees to the hoop, so the hoop lies horizontal, so droppings dont fall on it and stick.
Brent Swain is offline
post #103 of 165 Old 05-02-2013
troy2000's Avatar
The C-Head uses a stirring paddle at the end of a shaft that goes round and round in one direction, tumbling the contents until they're well -coated in peat moss. When you empty it, you're pouring out rounded dry clumps up to the size of a baseball, surrounded by loose peat moss.
I've never used an Air Head or Nature's Head. But I understand they use a horizontal shaft instead, with the stirring parts shaped something like the crankshaft in an engine.
"Ignorance more frequently begets confidence than does knowledge.
--Charles Darwin
troy2000 is offline
post #104 of 165 Old 05-02-2013
troy2000's Avatar
OK, so you'll get started on the toilet installation in what... two or three weeks?
Skipper Jer and Atlas like this.
--Charles Darwin
troy2000 is offline
post #105 of 165 Old 05-02-2013
Sound better. Can you give us a sketch of the paddle?
post #106 of 165 Old 05-03-2013
troy2000's Avatar
Settle for a photo?
--Charles Darwin
troy2000 is offline
post #107 of 165 Old 05-03-2013
krisscross's Avatar
Settle for a photo?
Dude, that must be a mil spec version of the composting toilet...
Plato
krisscross is offline
post #108 of 165 Old 05-03-2013
Settle for a photo?
Thanks
Where does that put the top stirring handle ?
post #109 of 165 Old 05-03-2013
Skipper Jer's Avatar
Maybe the shaft is connected to the handle via a belt or gear arrangement?
Nor'sea 27
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is offline
post #110 of 165 Old 05-03-2013
troy2000's Avatar
Nothing that high-tech. It's direct drive: the crank slips into the top of the hollow paddle shaft right through the top of the toilet, and has a notch on the end that engages a cross bar inside the shaft.
--Charles Darwin
troy2000 is offline
Tags
air head , composting toilet , head , waste odors
Air Head Composting Toilet arf145 Gear & Maintenance 32 09-16-2014 03:49 PM
composting toilet report genieskip Gear & Maintenance 442 04-18-2013 06:21 PM
Composting Head? saltyoldman General Discussion (sailing related) 35 01-10-2013 07:05 PM
Airhead composting toilet rwh Living Aboard 1 08-22-2003 06:57 AM
Airhead composting toilet rwh General Discussion (sailing related) 2 04-08-2003 03:55 AM
