Old 03-12-2004
oldcat is on a distinguished road
Hobie Hulls
I''ve got an old 16'' Hobie that rides low in the water with two adults on it. I check the hulls on a regular basis for water, and never find much. When I do I empty them out.
The boat is in decent condition considering her age.
The hulls are hollow except for some foam blocks where the trampoline frame enters the hull.
What''s her problem? What''s the solution?
Suggestions?
Old 03-12-2004
Yodagwb is on a distinguished road
Hobie Hulls
As long as the pontoon are dry you should have maximun flotation. Hobie 16 hulls don''t displace a lot of water so they do squat quite a bit with heavier loads, I speak from experience. I usually try moving forward a bit to get the weight centered over the most boyant part of the pontoon and then scoot back as the leeward pontoon''s nose thinks about burying.
Old 04-01-2004
ftldiver's Avatar
ftldiver is on a distinguished road
Hobie Hulls
agree, hobie16''s ride low unless at speed.
how much total wt onboard?
Hobie Cat racing in Narragansett Bay? natejount General Discussion (sailing related) 0 05-13-2003 06:51 AM
Hobie Cat racing in Narragansett Bay? natejount Racing 0 05-13-2003 06:51 AM
Are Col hulls cored? mrb2222 Boat Review and Purchase Forum 4 01-08-2002 03:59 AM
Hobie 16 Sailing Question aberger General Discussion (sailing related) 2 06-07-2001 04:59 PM
Hobie 16 Sailing to the Bahamas jmaddox Cruising & Liveaboard Forum 1 03-24-2001 04:17 PM
