Dual Charger *and* battery combiner - SailNet Community
 2Likes
post #1 of 11 Old 10-18-2012 Thread Starter
I recently purchased a boat, and I'm checking out the wiring (will verify or convert to Stu Jackson recommended battery switch configuration).
Interestingly, I've discovered that it has a dual output charger (Guest), as well as a battery combiner (Blu Sea ACR).
Under shore power, the dual output of the charger would appear to make the combiner redundant, but of course under alternator charging, the combiner would come into play.
But here's my quandary: It appears that the combiner essentially connects the dual outputs of the charger together, a practice which the Guest owner's manual seems to caution against. I could just disconnect and abandon one output of the charger, but I'm reluctant to give up the overall charging capacity (as well as the independent "smart charging" ability).
Any suggestions?
Russ
Rusty123 is offline
post #2 of 11 Old 10-18-2012
addict's Avatar
Send a message via MSN to addict
My stepdad had the same question. He emailed blue seas and their suggestion was to put a switch on the ground side of the acr. Without a ground the acr will not latch.
addict is offline
post #3 of 11 Old 10-18-2012 Thread Starter
Re: Dual Charger *and* battery combiner
Interesting. Instead of a switch, I could use a relay, such that when the charger is energized, the ACR is disabled.
Thanks!
Rusty123 is offline
post #4 of 11 Old 10-18-2012
Stu Jackson's Avatar
Sure, you could use a relay, but why complicate it? Put a toggle switch int he ground leg of the combiner. In fact, the Yandina combiner instructions mention doing just that. For an ACR, read the manual.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #5 of 11 Old 10-18-2012
Maine Sail's Avatar
What model Guest?
I would simply wire the charger as a single output to the house bank. We'd need the model of the charger to properly explain how to do that.
Depending upon the charger you may give up nothing or you can simply lead both red wires to one bank. This way you get the full output. If it is a distributed by demand type then using one output will be fine.
Sadly this is what many people "think" they get with a dual output charger. You still have ONE charger and ONE voltage yet two outputs with diodes. Each bank gets the same charge algorithm as the other. They are anything but "independent" smart charging.
Any suggestions?
Russ
Yep run it as a single output to the house bank and let the ACR do the rest...
chef2sail and mitiempo like this.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #6 of 11 Old 10-18-2012 Thread Starter
I'll check the model number tonight.
Russ
Rusty123 is offline
post #7 of 11 Old 10-18-2012 Thread Starter
Charger is a Guest "Cruising Series", model 2633A.
Manual contains the following statement: "Connection Warnings: Do NOT connect the outputs of the 2633A in series or parallel while charger is AC powered ON. Charge separate battery systems only. While charger is AC powered on, battery switch must be set to "OFF", "1", or "2", not "both".
From the specification sheet, it appears that one output is rated for 10 amps, and the other for 20.
Based on all this, the two outputs seem (to me) to be independent, which would imply that I should disconnect and abandon one output, or put a switch/relay in place to defeat the ACR while on shore power.
Comments?
Rusty123 is offline
post #8 of 11 Old 10-18-2012 Thread Starter
Also, while the manual doesn't specifically mention that the charging outputs operate independently, there are status lights for each output, and when I rotate the battery disconnect switch, the light pattern varies between the two outputs. In other words, each output seems to be "doing it's own thing".
Rusty123 is offline
post #9 of 11 Old 10-19-2012
mitiempo's Avatar
You are correct, the outputs are not designed to be combined. The switch in the ACR's negative is the best solution.
Brian
mitiempo is offline
post #10 of 11 Old 10-19-2012 Thread Starter
To me, the advantage of the relay is that it is "sailor proof". I agree that a switch has greater mechanical reliability, but when coupled with human factors (gotta remember to open the switch when connected to shore power, and then remember to open it when not), the overall reliability of a switch is lower than a relay, I suspect.
Rusty123 is offline
Installing Dual Batteries and dual battery switch lmddmc Gear & Maintenance 9 01-02-2009 01:51 PM
dual battery setup. dorourke Gear & Maintenance 16 06-07-2007 01:03 AM
dual group 27 battery box jackytdunaway Gear & Maintenance 5 04-23-2007 06:45 AM
combiner used with 3-step charger? rleslie Gear & Maintenance 1 10-03-2004 09:58 PM
Battery combiner vs battery isolator prelude General Discussion (sailing related) 2 07-09-2003 08:31 AM
