VHF Receive but not Transmit? - Page 2 - SailNet Community
post #11 of 15 Old 10-19-2012
night0wl's Avatar
Re: VHF Receive but not Transmit?
long shot, but check the transmit mode. I once had the same experience on channel 78...turns out my radio was set to international rather than usa. I guess international, 78a is reserved, but usa its open for all.
S/V Jendai
Beneteau 343
night0wl is offline
post #12 of 15 Old 10-22-2012 Thread Starter
Irrationally Exuberant
Back from the boat, and while I didn't have time to try everything, I did apparently fix it. And it does look like corrosion on the antenna connection to the radio was the problem, so thanks KBuckley! The coax connector outside looked fine, but unscrewing and pulling the connector off revealed a layer of corrosion inside, especially up in the pin. A replacement would have been good, but as a spot fix, I hit the area in question with a very small rasp attachment on my cordless Dremel. Screwed the connector back on, connected cable to the radio and was heard loud and clear at a marina down the bay. I'll try some other tests next time, including the auto Seatow radio check, but so far so good.
A new radio might still be in my near future, but I'd rather have it be an option instead of mandatory!
Thanks again everyone.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #13 of 15 Old 10-22-2012
That is great news. Thanks for the update.
KBuckley is offline
post #14 of 15 Old 10-22-2012
Tom,
If the connector is/was the problem, you don't need a new radio. Just cut the old one off, and put on a new PL-259 connector.
Bill
btrayfors is offline
post #15 of 15 Old 10-22-2012 Thread Starter
Oh, absolutely Bill. And I might replace any others I find in the antenna cable. I assume there's a connector up at the antenna. The talk of the new radio, was, well, just because it is old, and lacks features such as AIS, RAM mike, etc. But really, a new radio wasn't high on my constantly edited upgrade list. I really want cruise control!
Tom K
2000 Beneteau 331
arf145 is offline
MY BFS CUP I receive today OPTIMANIA General Discussion (sailing related) 23 02-18-2009 10:03 AM
receive no transmit jdair101 Gear & Maintenance 10 07-02-2008 07:59 AM
I receive a sail and a Wii! OPTIMANIA General Discussion (sailing related) 21 12-28-2007 09:28 AM
VHF Radio won't transmit scurvy Gear & Maintenance 19 07-14-2007 07:45 PM
What''s the best way to receive mail? prussell Cruising & Liveaboard Forum 5 04-02-2003 08:22 AM
