Like Tree5Likes
  #11
Old 10-19-2012
JimsCAL's Avatar
JimsCAL is on a distinguished road
Re: That Darn PO!!
You can put in a new fitting using a fitting relocation kit.
Marine Water Tank Fittings | Marine Holding Tank Fittings
  #12
Old 10-19-2012
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Re: That Darn PO!!
Since it's plastic tank & plastic fitting and it's water, not fuel (or holding ) I'd at least TRY gluing/sealing it in place first. Modern adhesives can be quite remarkable. A tank manufacturer should be able to tell you what will stick to it (3M 5200?)
What's the worst that can happen? - You're back where you started.
I, myself, personally intend to continue being outspoken, opinionated, intolerant of all fanatics, fools and ignoramuses, deeply suspicious of all those who have "found the answer" and on my bad days, downright rude.
  #13
Old 10-19-2012
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Re: That Darn PO!!
You could poison yourself with the wrong kind of adhesive. That's one thing the OP (not to be confused with PO) said he was worried about.
S/V Old Shoes
1973 Pearson 30 #255
  #14
Old 10-19-2012
SloopJonB's Avatar
Re: That Darn PO!!
That's why I referenced the (or a) tank manufacturer for their recommendations.
  #15
Old 10-19-2012
Minnewaska will become famous soon enough
Re: That Darn PO!!
I respect this point, but have to admit that I think it can be controlled or minimized to insignificant.
Jeanneau 54DS
  #16
Old 10-19-2012
Capt Len is on a distinguished road
Re: That Darn PO!!
Not much bonds to polyethylene . If removal of tank is not on your list , is it possible to cut an access hatch in the top and install a gasketed thruhull in the problem spot. Neoprene gasket and self tapping screws to a piece of cutting board.to seal the top. Lots of ways to skin cats but re/re still the best fix.
  #17
Old 10-19-2012
GaryHLucas is on a distinguished road
Re: That Darn PO!!
I work with poly tanks a lot, including the Ronco's. I install fittings up to 12" in tanks up to 12,500 gallons, thats 142" diameter x 16 feet tall! Currently working on a job with 6 12,500 gallon tanks, one 900 gallon, and four 65 gallon, all of which we will install about 30 fittings into.
If the tank doesn't have an inspection port, now is the time to install one. Once you have a port big enough for the flange of a bulkhead fitting to pass through you are all set. All you have to do is trim the spin welded fitting off flush with the outside of the tank using a coarse hacksaw blade. Then enlarge the hole to take the neck of the bulkhead fitting. Use a tape measure to reach across the tank to the hole, and slide the bulkhead down the tape measure into the hole from the inside. Don't forget the gasket! Then install the nut on the outside, and your tank is now better than new, because that bulkhead is removable and replaceable if it gets damaged, unlike the spinweld fitting.
Look at Hayward or Spears bulkheads, and get the EPDM gasket for potable water. Buna is fine too.
Gary H. Lucas
sww914 and paul323 like this.
  #18
Old 10-20-2012
dacap06 is on a distinguished road
Send a message via Yahoo to dacap06
Re: That Darn PO!!
Folks, thanks for your many replies. The knowledge of sailnetters is truly fantastic. I see some great advice here, and a couple of real jewels for my particular situation.
I was not aware that spin welding was a common capability. Thanks for that. Having a local firm spin weld a new fitting on the tank is greatly preferable. A special shout-out goes to Bubblehead, who gave me a firm name in Annapolis! That's less than an hour's drive from the boat. That's what I will do over the winter when I have the boat hauled in Nov.
Other techniques you mention would be equally valid but don't really work for my configuration. I do not want to permanently attach the valve with, say 5200 or epoxy as I have almost no clearance and I'd then have to disassemble the settee and knock out a tabbed bulkhead, or else ruin the tank, to remove it. Trying Teflon tape is a good idea and I already did that -- I used plumber's tape to try sealing the valve. I cannot relocate the valve. It is attached the the lowest point of a roughly triangular tank side. I'd end up with water I could not remove except by manual pump through the tank access, and I would need to cut a new hole in a tabbed bulkhead to put it in.
Regards,
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
  #19
Old 10-20-2012
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Re: That Darn PO!!
Tom, there are compression fittings that are designed to be installed in plastic tanks. No glue, no welding, no threading needed.
I think the link that Jimscal provided is for that type of fitting, we used to use them on chemical storage tanks and they are 100% reliable.
If you think of a plastic miushroom, with a hole running up the center of the stem and through the head? The head of the mushroom has a gasket (often a large flat gasket) under it. You put the mushroom inside the tank, pushing the "stem" through the hole in the tank wall. Then a similar gasket, washer, nut, are screwed onto the part of the 'stem" that is outside of the tank. Snug down the nut, and the tank wall is captured between the two gaskets and there's a 100% seal. Now just put your hose over the end of the stem, clamp it on, you're in business.
No need to pull the tank, just put the new fitting in the old hole, drill or ream the hole as necessary to get the sizes to match.
This is pretty much exactly the same as installing a through-hull in the hull of your boat, if you can't find plastic tank fittings, look for a small marelon through-hull and see what you can adapt from there. The tank kits will have gasket sets, etc, the through-hull will require a little more parts shopping, either way, no big deal, no need to pull the tank!
chef2sail and SloopJonB like this.
  #20
Old 10-20-2012
SJ34 is on a distinguished road
Re: That Darn PO!!
My vote would be for the suggestion to tap the outlet for the next size up NPT fitting. If the current size is 1/2 then go to 5/8, if 5/8 then up to 3/4 and so on.
This would be the cheapest and easiest fix and if for some reason it didn't work it wouldn't eliminate the other fixes.
You may post attachments
You may edit your posts
those darn thru hulls... Mark S. Gear & Maintenance 17 03-20-2012 11:48 AM
darn seacock QuickMick Atomic 4 5 05-06-2010 06:43 PM
Darn poprivets QuickMick Gear & Maintenance 10 04-22-2010 11:11 AM
darn deck stains QuickMick Gear & Maintenance 2 11-11-2009 05:14 PM
SEO by vBSEO 3.6.1
