Combo Washer and Dryer... Vented or not ? - SailNet Community
post #1 of 4 Old 10-21-2012 Thread Starter
We have a Splendide washer and dryer. The water solenoids are not working as they should, There is some corrosion nothing real bad that can't be fixed but the Admiral is not happy about it so... Christmas will come early and we will replace it.
The drying cycle was never appreciated and she prefer hanging the clothes with the fans On and the dehumidifier.
We have a Hunter 450 and I'm questioning where could we install the vent ? Saw from forums that a vented one is more efficient. My concern is not about water usage we have a large 45 gals/hour watermaker. Just trying to keep the Admiral happy..
By the way we are in Fort Pierce and if someone want a good deal on a used Splendide Dirt cheap but you will supply elbow grease to get it out and the new in.
Pierre
CharliePapa is offline
post #2 of 4 Old 10-21-2012
Brezzin's Avatar
I have a vented one and although I can't compare dry time to a non-vented one. The vented one still sucks.
Dave
s/v "eclipse"
Mystic CT
2007 Hunter 49
Brezzin is offline
post #3 of 4 Old 10-22-2012 Thread Starter
Re: Combo Washer and Dryer... Vented or not ?
Could you tell me whhere the outlet of the vent is located ? On the hull topside or in the back storage cabinet ?
Pierre
post #4 of 4 Old 10-22-2012
Have you ever seen the rotted siding next to the dryer vent on a house. I would be concerned about hot humid steam causing other trouble.
We also have the non-vented. We try to use as much micro-fiber as possible, which dries very easily. For other items, we run the dry cycle for the shortest period (I can't recall if its 20 or 30 mins). If you take it out warm, it seems to dry faster when hung up.
The bigger problem is the units are very small and its easy to overload them. Overloading really takes forever to dry. In fact, if you do dry cottons in an overloaded drier, they come out wrinkled and creased. Nothing ever tumbles around.
Jeanneau 54DS
Minnewaska is offline
washer/dryer/dishwasher combo - does it exist? rmeador Gear & Maintenance 17 12-12-2012 06:49 AM
Looking for a dryer boat - desiccant? jarcher Gear & Maintenance 9 06-14-2009 10:46 PM
Fuel Tank Blues. Gas dryer? Adam1986 Gear & Maintenance 27 05-18-2009 11:33 PM
Washer/Dryer onboard reid5009 Living Aboard 6 06-17-2007 11:09 PM
washer dryer combo KenD Gear & Maintenance 2 07-02-2002 04:59 AM
