VHF Antenna - Page 2 - SailNet Community
 5Likes
post #11 of 16 Old 10-23-2012
chef2sail's Avatar
Re: VHF Antenna
Almost all new VHF have DISC and many now are equipped with AIS. These both are safety measures. Not using the highest point is probably the best place to put it as well as the best and lowest resistance coax you can use.
I once had a 5 ft Shakespeare mounted off the stern of my boat....distance at best was 10 miles. Same coax and VHF now mounted top the top of the mast distance is at least 22 sometimes 30 depending on atmospheric conditions.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
post #12 of 16 Old 10-23-2012
Re: VHF Antenna
Whether you use HT or a mounted VHF, my recommendation is to have a backup (at least one, in addition to your primary). Murphy's law works aptly well in the marine envirnment. There are pros and cons to either side of this subject. The best thing to do is weigh options as they apply to you. Every person is different and so are their preferences. My opinion is to have a chassis mount radio with the antenna sitting on top the mast. I just want my signal to reach as far as possible if/when necessary. HTs usually only put out 5 watts or so, where the bigger units give a full 25W. I also prefer the least amount of connections between radio and antenna. Again, this is my opinion. Mounting your antenna on the rail limits your ability. A line of sight calculation will show just how much difference. Keep in mind this is theoretical distances. Atmospheric conditions can both hinder and enhance VHF performance. It just depends on what mother nature wants to dish out.
Good luck in your decision.
KG
Not all who wander are lost. - JRR Tolkien
Kajungizmo is offline
post #13 of 16 Old 01-15-2013
jz5w63
Re: VHF Antenna
I got screwed by Baron USA via an Ebay purchase Baron sent me a 8 ft. powerboat antenna instead of the 3 ft. sailboat antenna I ordered. Ebay/Pay Pal did refund my purchase (no response whatsoever from Baron) but I don't think this 8 ft. deck mount Shakespeare will work as well as a 3db. whip antenna off the mast head. Nor do I think I have the room on the stern rail or aft deck of my Hunter 25 to mount it but could shuffle a few things. Should I just sell the sucker and buy a 3 ft whip for the mast head or try to use the 8 ft.??? Advice?
jz5w63 is offline
post #14 of 16 Old 01-15-2013
chef2sail's Avatar
Re: VHF Antenna
It will work if you get a mount for the deck or rail and then wire it through the deck,
however it will not get as much distance as the whip at the masthead will.
SHAKESPEARE Mount at West Marine
Parkville, Maryland
Our blog-
post #15 of 16 Old 01-15-2013
Re: VHF Antenna
The real issue is the 8ft antenna's gain. They are normally 6db which means a tighter focus - which could be a problem when you are sailing, and heeled. The reason sailboats normally use 3db antennas is that they work well on a heeling boat.
So, yes, I think you should sell it and get a 3db one for the mast. So you now have an 8ft antenna, AND your money back, which will, presumably, pay for a 3db one and leave you some change? How does this equate to getting screwed?
MarkSF is offline
post #16 of 16 Old 01-15-2013
Re: VHF Antenna
Contact Shakespeare, see if they'll do a swap for you.
hellosailor is offline
SSB wire antenna to antenna feed-line connector scud Electronics 0 09-24-2012 09:50 AM
SSB Antenna dpoissant Electronics 7 09-10-2010 11:24 PM
AM FM Antenna buddabelly Gear & Maintenance 9 02-04-2008 10:45 PM
tv antenna dm567 Gear & Maintenance 44 04-15-2007 09:50 PM
VHF antenna demetrik2 Gear & Maintenance 2 01-14-2004 06:18 PM
