Winches - SailNet Community
 2Likes
  • 2 Post By RocketScience
post #1 of 6 Old 10-23-2012 Thread Starter
Question Winches
Hello everyone I have 2 Andersen 40 Two speed winches they are not self tailing, can anyone advise if I can buy the self tailing separately they would just fit into the winch handle and do the job of a self tailer. Andersen says I have to but new winches but mine are stiil in pristine condition. Any thoughts would be appreciated.
Phil
phil4878 is offline
post #2 of 6 Old 10-23-2012
Re: Winches
You generally can't convert non-ST To ST winches. There are two many differences in the internal parts for it to work. Sadly this is why I hate new boat builders that even make nons an option on new boats. It's a rediculous way to save a few undated bucks.
Greg
Stumble is offline
post #3 of 6 Old 10-23-2012
SchockT's Avatar
Re: Winches
You should just sell your winches and put the money towards the STs. It will cost b bit more, but you will be glad you did! I just put Andersen 40 STs on my boat and I love them!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
post #4 of 6 Old 01-16-2013
Re: Winches
Looking for coffee grinder in the size 65-75 or slightly larger,
Also 2 -55-65 prefer SelfTailing but will consider Standard.
Cphinc is offline
post #5 of 6 Old 01-19-2013
Re: Winches
I have a pair of Barient 22 stainless two speed winches on my 1973 C&C 30. They work well except the needle-peened finish is worn smooth and itís sometimes hard to keep the sheet from slipping when trimming the jib sheet.
Do you have any ideas on how to refinish the drums? Or where I might send them to have this done?
It has been suggested that a machine shop can knurl the drums, but Iím worried about creating too much friction or damaging the inside bearing surface.
Lawrie is offline
post #6 of 6 Old 01-19-2013
RocketScience's Avatar
Re: Winches
Originally Posted by Lawrie View Post
I have a pair of Barient 22 stainless two speed winches on my 1973 C&C 30. They work well except the needle-peened finish is worn smooth and it’s sometimes hard to keep the sheet from slipping when trimming the jib sheet.
It has been suggested that a machine shop can knurl the drums, but I’m worried about creating too much friction or damaging the inside bearing surface.
If your drums are indeed stainless, you can have them masked-off, and the appropriate area sand blasted with a very course media. Any reputable sand blaster should be able to show you samples of the different finishes they can obtain. Good luck!
Gary M and SloopJonB like this.
Synthetic Rigged Wauquiez Pretorien 35
RocketScience is offline
winches from a 41' '79 QuickMick Cheoy Lee 0 06-15-2010 12:55 PM
new winches ambianceack Gear & Maintenance 4 06-14-2010 11:20 AM
Winches saurav16 Learning to Sail 44 06-19-2007 11:47 PM
